Question about True GDM-49FC Refrigerator Commercial
Freezer not keeping things frozen
The freezer is not keeping the frozen food frozen. The thermometer reads 20 degrees farenheit but the frozen food products are soft and unfrozen. what needs to be done to be fixed?
  • 1 more comment
  • lindasaslove Mar 19, 2009
    How do you adjust freezer temp when there is only a knob in the fridge?
    I am trying to freezer freezer bowl for ice cream maker. It is still sloshing (coolant in bowl) and the other day when I actually made ice cream in ice cream maker and then placed in freezer to harden, the ice cream never hardened like it is supposed to.
  • Anonymous Mar 13, 2014
    food no longer frozen solid in freezer
  • 64 Answers
Ice cream requires a significantly lower freezing point than other foods. Keep it near the blowers or coils in most freezers and you'll be OK. Turn up the freezer a bit, and if it is all the way then move it away from the wall a bit more hope this helps!
Posted on Jul 26, 2007
SOURCE:
The freezer is to cold
I do assume this is in Celcius.
-20C is about the right level for a three-star freezer.
From Google:
  1. Domestic freezers have a star rating indicating the temperature they are designed to operate at. On the packaging of a frozen food there is guidance stating how long the food can be stored using freezers of a given star rating. As a guide here are some suggested maximum storage times at -18°C for a variety of foods."
Feb 12, 2015 | Freezers
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
What should the temperature be set on for a
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Aug 30, 2014 | Kenmore Refrigerators
The freezer door was left wide open for most of the day. Will this destroy the freezer?
Hello Scott. No. The only thing it does is run up the electric bill and possibly cause the frozen food to deteriorate more rapidly than it would if it was kept at zero degrees farenheit or lower. Joe
Thanks for choosing Fixya!
Nov 30, 2010 | Woods Upright Freezer V1613RW3
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Jun 28, 2010 | Magic Chef CTF2125 Top Freezer...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
True GDM-49FC Refrigerator Commercial Logo
903 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
