Question about Dell Dimension 4500S PC Desktop
Plug and play configuration error
Start computer gives plug and play configuration error and will not boot up
    Genius:
  • 1,913 Answers
Reconnect all cables device to cpu .remove usb device if ther eis connect then asfter loading the operting system connect again.
Posted on Jan 29, 2009
  • 479 Answers
Go in bios then checked wether plug and play support is enabled or not? enable it and this should work.
Plug & Play Configuration Error
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
Nov 30, 2011 | Dell Dimension 8200 PC Desktop
Main OS does not mount
Boot in safe mode
Start msconfig.exe and configure windows to start with a clean boot.
a. Log on to the computer by using an account that has administrator rights.
b. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
c. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
d. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
e. Click OK, and then click Restart.
Boot the machine in normal mode.
Nov 11, 2011 | Compaq Hewlett Packard Presario SR5110NX ...
Plug and play configuration error.I have been told to press F1 key to continue BUT nothing is happening
restart the desktop, hit F2 as soon as it is booting. This will take you into setup.there you can see what is happenning under the plug and play heading, or set it to default and restart the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 25, 2010 | Dell Dimension 8200 PC Desktop
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
When turning on computer it gives me an error message saying no boot disk please insert boot disk
press f12 during start up and select your harddisk and if that doesnt solve it take out your harddisk (large plate that you can remove at bottem of laptop)
and boot your laptop switch it off put in harddisk and switch on again
Apr 20, 2010 | Acer Aspire One PC Notebook
My computer has a plug and play configuration error on start up, and after it boots the display is distorted
Might be Plug and play option in system BIOS is Disable.So pls Enable from BIOS.For enable press Del. or F2 button continiously untill BIOS screen comes ,then choose a option plug and play and Enable it.
Nov 17, 2009 | Dell Dimension 8200 PC Desktop
I have a va2223wm monitor out of the box..and trying to install. it is giving me an error that says out of range. what do i do?
Start the computer with the monitor attached. It should discover a plug and play monitor and adjust the resolution to a setting that your monitor accepts. If it doesn't, boot the computer with your old monitor, go to screen preferences, choose advanced, monitor, and change the monitor type (driver) to Plug and Play monitor. Now do what I suggested above.
Oct 27, 2009 | ViewSonic VX2235wm LCD Monitor
I installed 4gb of memory 4x1GB 240 pin and when booting up the computer recieved the decomplilation or disassembly prohibited.  What do I do?
HI there,
If you have installed the memory module correctly and are the right ones, than go into your bois and in there should be overwrite o clear this message.
Its only an alert message when you pc has been opened.
Regards,
Philip
Dec 06, 2008 | Dell Optiplex GX280 (99301) Motherboard
When i start my computer a problem occurs that searching for boot record de-o..ok and then hangs
use the windows cd to perform a repair installation if you get startup errors or the system wont start.
May 28, 2008 | Microsoft Windows XP Professional With...
Dell Dimension 4500S PC Desktop Logo
472 people viewed this question
Alun Cox
