Question about Toshiba 57H81 57" Rear Projection Television
Blank Screen I have power, sound but no picture
    President:
  • 1,990 Answers
Welcome to Fixya! You need a new HV transformer. Usually you can just buy the transformer itself. It's a little black tower on the backside of the tv. If it's not that, it's the convergence ic's. There's two of them, given it's a toshiba, the part number is more than likely stk392-110. Please Rate My Response! Thanks!
Posted on Jan 30, 2009
    Sergeant:
    Champion:
  • 318 Answers
There is a fuse on the main power board which may have blown. you need to check your schematic manual which will usually be located somewhere on the rear of the TV,for the exact location in your case.
Be very careful when operating near these electrical components because even if the TV is unplugged it can give you a nasty shock from stored voltage.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to Fixya,
In most instances, there would be a blinking LED light. The sequence and number of blinks actually represent a particular error code. With the number/sequence known, then what section or general area to begin the diagnosis would be pointed.
Pls post back number/sequence of blinks. Further, pls confirm if you are considering a DIY (do-it-yourself) amd stage of familiarity with electronic components & circuitry use and availability of a DVM/VOM and a soldering iron.
Good luck and thank you for using FixYa.
  • 10,594 Answers
Please check CRT Guns at rear of TV heater glows at base ?
This will confirm that Horizontal section is working and problem is in hyper board of TV.
Let me know results to help you further.
Thanks.
    Sergeant:
  • 285 Answers
I think you'll need to buy a new picture engine, since rear projections degrade over time. Call support and they'll diagnose it for sure and sell you a new picture engine. I estimate it'll cost about $75. I hope this helps. Please rate my solution.
Have 21,6umc switch on after 3-6mins picture & sound go off with a click, just left with blank screen with
Power supply problem, intermittent voltage regulator ic after it heats up it shorts out internally and tv shuts off.
Nov 18, 2011 | Televison & Video
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Repalaced bad capaitor(bulge on top) Now powers up. snowy with sound and picture goes blank. With nothing on screen. Tried to use remote but nothing shows up on screen. Note the snow is from not being...
When the filter caps went bad, the power supply output will be AC and feeding the circuits which can damaged the parts on the board. Check to see if you have the 12 or 18v feeding the back light invereter board. There are surface mounted fuses on the inverter board also. Send me good pictures of the whole back where all the boards are and close up picture of the inverter board, may be I walk you through. budmrtn@aol.com
Dec 10, 2009 | Westinghouse SK-19H210S Television
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blank screen;no picture, no sound
I have a philips universal remote changed batteries now the codes lost
Aug 06, 2009 | Soyo DYLT032D 32 in. LCD Television
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Blank screen,power led on, fans running
Do you have a DLP or Plasma set????? Give me the model #.
Apr 01, 2008 | Hitachi 60SDX88B 60" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
