Question about OEM Systems Bluetooth Headsets - Model BTCC1357A Headset
Pairing with Nokia N95
Please can someone let me know how I can pair with my Nokia as I have lost the user guide for the AOEM GW-BT-002?
    Problem Solver:
  • 5 Answers
I posted the manual to this headset here
http://www.fixya.com/support/t526500-cannot_pair_aoem_bluetooth_headset_lg
Posted on May 14, 2009
How can i pair my plantronics m100 BT headset with my Nokia E63 I have tried all the usual ideas without success.
Try turning both devices off and then back on, put them in pairing mode and see if that works. Here is the link for the Plantronics M100 user's Guide.
Good luck from Headsets Direct!
Mar 05, 2011 | Nokia E63 Cell Phone
I have nokia n95 phone. may i know the pairing code of for SBH650 for connecting
  1. Enter Pairing mode.
    • Slide the power switch on.jpg with pressing and holding [ talk.jpg ] to turn the headset on. The indicator light turns on blue and stays lit after flashing blue, red, and purple twice.
    • If you turn the headset on for the first time, it proceeds into Pairing mode immediately.
  2. Search for and connect with your phone according to your phone user's guide. (Bluetooth PIN: 0000, 4 zeros).
  3. i hope this helpfull
  4. if you think this helpfull, please rate very helpfull
  5. thanks for using fixya
Jan 24, 2011 | Samsung OEM SBH650 Bluetooth Stereo...
Lost My pin for the bluetooth AOEM GW-BT-002 headset. the generic 0000 pin does not work and neighter does the 8888
Hi johan56s The pin is 1234. Hope this helps ???
My problem is,that i can make a call using my ear piece,but not sure on how to receive a call via ear piece.If i just answear via Mobile, can only hear through phone.Wish i didn't mislay my handbooks. Hope someone can help. Cheers Waveslider123
May 24, 2010 | Motorola Cell Phones
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Power up
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the AOEM device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 14, 2008 | Motorola Mobility HS850 Consumer Headset
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Apr 19, 2008 | Radio Communications
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Mar 31, 2008 | OEM Systems Bluetooth Headsets - Model...
Bluetooth to mobile pairing
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
New bluetooth earpiece, no instructions
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done.
Radio Communications Logo
394 people viewed this question
Top OEM Systems Radio Communications Experts
eradiostore
eradiostore
Are you an OEM Systems Radio Communication Expert? Answer questions, earn points and help others
