Question about Intel ER8100UUS, Express 8100 Router, VPN Router for Secure Networking Over the Internet (ER8100USRP)
Networking two PC's from different ADSL routers?
I need to access a database on a PC on on ADSL router from another PC on another ADSL router. Any thoughts?
  • 78 Answers
Maybe a 3rd router to connect the two networks.
Posted on Jan 29, 2009
  • 68 Answers
Well if you are on both public IPs u need an application which will access the database from the remote side.
check and see the IP and also if they are NAT'ed or not....
What kinds of ADSL access way divided into?
ADSL access namely use parallel twisted-pair cable access user home, using M connected PC, whether it's special line, virtual, routing, all leave twisted-pair and MODEM.White said again is to run the business broadband signal through the circuit access user home, using computer dial-up MODEM connection.As for the access network equipment, PON, connection cable trunk, wiring, equal twisted-pair, client PC, router, such as TV all need to slowly in the actual operation experience.
Oct 30, 2015 | Computers & Internet
How do I connect my Netgear DGND3700 router to Fibre internet (BT infinity)
Hi there
Your Netgear router will not connect to BT Infinity directly as the built-in modem is ADSL/ADSL2+ and Fibre requires a VDSL modem as in the HomeHub5 or the BT Openreach modem. Either of these can be used with your Netgear as a subsidiary router/access point. You may now be able to get a router with a VDSL modem built in but 3 years ago it was really only available from BT and BT did not support other makes.
Hope this clarifies matters though perhaps not too helpful
Nov 08, 2014 | Network Computing Devices (NSH800S/A)...
Internet light on router diplayed red
The ADSL installation details have changed, so you need to update the router.
Check the router has not been moved too far from the laptop.
Jan 27, 2014 | NetGear DG834G Router
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
I have a Zoom 6 router and Windows VISTA. Internet is fine on pc One, local area networking doesn't work
Provide more detail information for further assistance.
1.2nd device = wireless or hard connect??
2.Model numbers of each device?
3.Browser used? Explorer or Firefox etc.?
4. Laptop or Desktop??
May 16, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
I need to complet my router setup
Have you secured your Linksys from unauthorized access?
The encryption code protects your wireless router from unauthorized access. The wireless card in your computer/laptop needs to be configured with the router's encryption settings before the computer/laptop can access the router.
For details on configuring the wireless router and the wireless card, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
Sep 03, 2008 | Computers & Internet
I am connected to the access point but the internet cannot be found
an Access point is to add Wireless to a LAN. (which is ok if you have a Router connected to your LAN).
if you have no Router,  and only have an ADSL/Cable modem connected to a PC then you should have got a Router +ADSL/Cable modem instead of an Access point.  you can get routers like this which also have wireless, so you get all the functionality in 1 box
Here is a Wireless router, with hub and ADSL +Cable Support
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1133202177241&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7724139789B01
Oct 13, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Intel ER8100UUS, Express 8100 Router, VPN Router for Secure Networking Over the Internet (ER8100USRP) Logo
60 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
