Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio jive shuts off with loud noise
What is the problem and how much will the problem cost me?
Look for blown capacitors on the main power board. in many cases the capacitors blow causing the powerboard to no longer capable of building up enough charge to power the remaining boards
Posted on Jun 08, 2011
    New Friend:
  • 56 Answers
This could cause by the audio board.
Posted on Feb 17, 2009
My vizio m3d650sv turns on and plays fine for any where from 5 mins or maybe even an hour. And then makes a loud popping noise and the screen goes all distorted and shuts it's self off. I can immediately...
Vizio 0500-0507-0920 (DPS-353AP) Power Supply for M3D650SV are the part numbers. The actual part number is on the board. The item is not in stock and may be obsolete.
Jul 19, 2017 | Vizio Televison & Video
Vizio tv model #e701i-a3 turns on then after minute make loud noise and shuts off. can you tell me whats wrong with this TV?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 11, 2017 | Vizio Televison & Video
Vizio E422VLE--heard a loud pop,then shuts off. Won't turn back on unless I power cycle, but does same thing when I turn it on again. Already took the back off the tv. All the capacitors look fine. Any...
You will need a voltmeter to actually check the capcitors. More than likely it is a blown capacitor as that is one of the only components that is going to make an actual noise if it fails. Good luck.
Jan 07, 2015 | Vizio Televison & Video
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
Why does my 32 in. Vizio make a loud noise and then turn off?
There is something shorting inside, possibly due to moisture collection. First, change input device to some other and see, if it works fine, the problem is with the input device. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Vizio L32 32 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
My Vizio picture went out and tv made a loud noise. It doesnt show visual ane no audio. Its a VX32L HDTV 10A model.
Most likely the TV has a power supply related problem. It's very possible that it maybe a bad capacitor or transformer on the power supply board that made the loud noise. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. If by chance the TV is still under warranty, go that route.
2. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 14, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio TV issue
this is an indication that the power supply is working. The clicking noise shows that the power supply is booting up. If you still does not have power, it may be the main board that is not working.
Nov 10, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
156 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
