Question about GE (PSS26MSRSS) Side by Side Refrigerator
ZIS480DRISS NO MAKING ICE CUBES
BIG LOU
MY ICE MAKER GREEN LED IS BLINKING
FINGERS THAT EJECT THE CUBES WAS JAMMED ON WHITE PLASTIC. REMOVED ICE MAKER THAWED CUBES IN THE TREY AND PRYED AWAY THE WHITE PLASTIC COVER. RE-INSTALLED
Posted on Jan 30, 2009
Hoshizaki km151bah ice machine not making cubes. ice is coming out in one big sheet. Why?
The depth setting on the evaporator cube setting may be set too thick making the cubes stick together. Adjust it to make smaller cubes.
Feb 28, 2015 | Hoshizaki KM-151BAH 121 Pound...
GE refrigerator is not making ice
There are several types of ice makers with the same model number. Some of my questions may seem over - the - top, but I do not know your level of ability. Do not take offense.
Did this ice maker ever work before, or is it a newly installed maker or a factory installed maker in a new fridge? Have you moved the power switch to on? If yours has an LED power indicator, is it off, blinking or on? Off means there's no power to the maker - you'll need to get the maker powered up before going further (make sure the electrical power connector is mated fully). Blinking means cubes have become stuck in the maker. You'll have to shut the maker off, remove the cubes then power up again. On means it is powered and is working normally. Is the freezer compartment set to maintain a temperature lower than 15 degrees F (-9 C)? The ice maker will not make ice unless the temperature is below 15 F (-9 C). The space under the maker must remain clear of obstructions so that the sweeper arm is not blocked (when blocked indicates a full ice container and will halt ice production until the arm can move freely again). The maker may need as many as 3 cycles (approx 6 hours) before all the air in the ice maker's water lines have been purged completely.
Listen for the solenoid valve to operate. Every couple of hours, this valve should operate and an audible click on and click off heard after a several seconds (as long as set on the ice maker cube size adjustment knob). When this solenoid has clicked on, water should be flowing through the lines and filling the ice maker. If not, there is an obstruction that must be cleared. A dirty or improperly installed filter, pinched line, and even ice can interrupt flow to the ice maker. You might need to remove the ice maker from the freezer to check the water supply line that feeds it for the presence of ice. Melt / clear as needed.
Jan 23, 2012 | GE GSS25LGM Side by Side Refrigerator
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
Icemaker not making ice. Green LED is ON, no
you have a dual water valve that sends water to the ice maker and the water in the door and it is very common for the ice maker side or the water side of the valve to go bad and on of them working properly and the other not
Apr 09, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Refrigerator has stopped making ice and the light is blinking above the ice maker switch. what do i need to do to correct this problem?
My book says that ice cubes may be stuck in the ince maker.
Turn off the icemaker, remove the cubes and turn the icemaker gake on.
Feb 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
Ice maker not working
is there a filter on the water line? if so check and replace as neccesary-usually all water going into a fridge ice maker is filtered if it was installed properly for fresh tasting ice......if not there usually is a valve where the water line connects to one of your houses water line ....be careful with that but make sure it is all the way open......maybe try cleaning or replacing the lines if it comes down to it. let me know what happens.
Sep 30, 2008 | Maytag MBF2256H Bottom Freezer...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
122 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
