Question about Samsung HCL4715W 47" Rear Projection Television
TV won't power on
My Samsung HCL4715W rear projection TV won't power on. It won't respond to either the remote or the power button. I unplugged it and when I plugged it in there would be a pair of clicks and the TIMER LED on the front panel would illuminate, then the LED would go dark and the "click-LED on" sequence would repeat over and over again.
    President:
  • 3,130 Answers
Disconnect the convergence board and see if the set comes on. If it does, and it probably will, replace the convergence board or the convergence amp IC's. Good Luck
Posted on Jul 27, 2007
SOURCE:
Set TV to Auto ON/Auto Off.
hit menu button on remote....should be an option for power settings....check auto shut off option...
Jan 15, 2012 | Samsung HCL4715W 47" Rear Projection...
Power on and off w/remote not w/tv no pic or sound
has a very different problem because if the fuse does not ignite the fuse you have to do is check voltages with a manual of your computer
Aug 21, 2009 | Samsung HCL4715W 47" Rear Projection...
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Convergence Board for hcl4715w Samsung TV
Part can be found at http://www.vancebaldwin.com - the part is located on the floor of the tv, inside, the middle board. You will have to unplug the tv, carefully remove the back (and front speaker cover) of the tv, and unplug all of wires coming into it. You will also have to remove all of the screws holding it down. The replacement part will fit exactly into the same place - screw the screws back in, plug the wires back into the same place (if you've ever replaced memory in a computer, this will feel very familiar). Once everything is plugged back up, plug in the tv and restart, then run the smart convergence from the remote.
If your TV does not power up, and you have made VERY sure everything is plugged in correctly, then the board you've purchased may be faulty. Return it for a new one. The boards are fragile and can be bad straight out of the box (like computer memory *smile*).
Best wishes -
Jan 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
48inch Samsung Tantum Rear Projection, turns on then turns itself off again straight away!
Your power button may be stuck? Depress it with the TV unplugged. Make sure that the button is moving in and out properly. If this does not fix the problem, it probably needs service by an authorized service center.
Oct 24, 2008 | Samsung HCL4715W 47" Rear Projection...
Help me fix my 60 inch projection samsung
try unplugging the three convergence yoke plugs then try powering up the set if it powers up the Convergence ICs are bad and will need replacement.
Jul 25, 2008 | Samsung HCL4715W 47" Rear Projection...
27 in samsung tv
TRY UNPLUGGING THE T.V. FOR TEN MINUTES. THE TRY THE BUTTON ON THE FRONT OF THE SET. YOU SHOULD BE ABLE TO GET AN ORIGINAL REMOTE FOR AROUND $40 .
DON.
Jun 12, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
138 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
