Question about Xerox Phaser 8550DX Laser Printer
37, 011.47;36762 then it says "service error" any suggestions?
  • smalik Jan 31, 2009
    I changed the entire "Ink dispenser" and that resolved the issue. Thanks the the quick response!
    I replaced the entire "ink dispenser" unit and it fixed the problem...thanks for the quick reply!
    President:
  • 2,072 Answers
That is a fault in the start up procedure of the printer. Xerox calls it of all things PEST. Most of the time, it is a failure of the electronics module.
That is both difficult and expensive to replace. I am estimating for a new one, in the $1000 range from Xerox. A third party may be able to fix it for less, but that module is almost the entire electronics of the machine.
Wish I had an easier answer for you.
Posted on Jan 31, 2009
  • Rick Kasper Feb 01, 2009
    Wow, that's an interesting fix for that code.
    Thanks for answering back, and sending that info.
    Thank you.
Error zoom finepix s1000 fd
My first suggestion is to remove batteries and put a new set inside of the camera. Sometime the power fluctuation will jam the mechanism and give you a zoom error. If this does not solve your problem then the lens is probably damaged or out of alignment and needs to be serviced. I suggest you look for the local service center; I know Photo Tech is the authorized service center in NYC. www.phototech.com and they do most of those repairs at their facility.
Good Luck,
Paul
Jun 30, 2011 | Fuji FinePix S1000FD Digital Camera
960 service memory error - a
The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
Sep 10, 2010 | Lexmark C530dn Laser Printer
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
"981 Service Switch Error" and "994 Servise Density Sensor"
these are internal error. beyond user capability or repair
turn off the printer and check all of the cable connections.
turn on the printer, you need to call lexmark service, if the error returns.
Feb 17, 2008 | Lexmark C912 Led Printer
913 Service Fan Error
your printers power section does not work properly
Jan 25, 2008 | Lexmark C510 Laser Printer
Stove question
According to the service sheet E2F3 error code means keypad spill. Solution: clean keypad.  The solution suggested did not work for me. I also sometimes get the E2F1 error code in which the service sheet suggests that the cancel key is invalid. Solution: clean surface.  I think that either my key pad is shorted or that there is a malfunction of the power board. In either case $$$
Oct 18, 2007 | KitchenAid KGST307 Gas Kitchen Range
Xerox Phaser  8550DX Laser Printer Logo
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
