Question about Belling XOU487 Electric Double Oven
My belling oven door
My oven door has come away from its hinges, now the hinges seem to be just glued on in the first place so im wondering what glue to use to fix it thanks
  • 5 Answers
Get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Posted on Mar 29, 2010
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
I have an Indesit oven FI 31 KB. It is 3 years old but never used as it is in a house I have just renovated. I turned the oven on, but the fan did not come on as it is expected to do. Oven and light seem...
sometimes there is a switch that operates when the door is opened or closed causes the fan to stop when the door opens. The switch is normally mounted at a door hinge, or hinge bracket.might have to remove a panal to get to it
Oct 19, 2013 | Belling XOU492 Electric Double Oven
Oven door has come apart and front section has come off the door. Now have only one pane of glass on the interior side of the oven. It looks as though it has been glued in place, what do I need to do to...
I am afraid that yours is a common problem. The front glass normally has some small brackets glued to the inside face, which then locate into the door frame. The link will take you to a site that sells oven door glue
Feb 11, 2011 | Fisher and Paykel AeroTech - OS302M...
Wall oven, the front of the door has fallen off - glued on by the looks. So now instead of handle and window I now have one glass panel. I need to re glue it I presume. What glue would I use.
This is the correct Heat Resistant Adhesive
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
How do i take the oven door off? The handle has come off on one side and the screw is now inside the door. I assume i need to take the door off and unscrew somewhere??
In general, most oven doors can be lifted up and off when they are in the 'just or slightly open' position. The hinges have a 'hook' on them which slides down and hold the hinge in securely. So Check where your door 'hinges' and look for a vertical slot the door disappears into - try lifting it up then out.
Once its off, look for screws on the inside or on the edge of the door - they will get you inside the door itself. Watch out for glass insulation fibres ( if its very old may even be asbestos... those fibres are highly dangerous to breathe in...long term they are fatal !!)
If it has a glass see through window, its a good time to clean all the glass ( use oven cleaner on burnt on stuff). Find and replace the screw and use some thread locker on the thread before you screw it in. No locker?? try some super glue, but screw in real fast and tight before its sets and do the other screw at the same time. (Chances are you will never have to do it a 2nd time so who care if the screws are glued in anyway)
Nov 07, 2009 | Ovens
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 | Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Zanussi oven ZBF360 X, Door coming off
You Can buy Heat Resistant Glue at Espares.co.uk
Worked for me!
Aug 23, 2008 | Zanussi ZBF360X Electric Single Oven
Belling XOU487 Electric Double Oven Logo
441 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
