Question about Samsung LN32A330 32 in. LCD TV
No Sound from my Samsung LCD TV
Hi. About a month ago the sound stopped working on my 2 year old, Samsung LCD TV Model number LE23R8. I tried all the obvious stuff, mute button, audio settings, power on/off etc. I found on the web a comment that certain Samsung tv's have an issue with their Audio chip. It also mentioned a Firmware fix may be available (via USB thumb drive). If its of relevance I live in Ireland. Any ideas?
  • 1 more comment
  • richodon Jan 31, 2009
    Yes, I have tried the Audio settings on the menu - numerous times. I tried plugging in the headphones as you suggested however still no sound. Have you heard of the firmware update I heard about and where I might get it?
    Hi. I don't get an error message, I get the 'volume bar'
  • richodon Feb 03, 2009
  • Samsung Master
  • 19,396 Answers
Try plugging in and unplugging headphones.
If you still get no sound there is an internal fault, and you need to call a technician.
Call the phone number listed on the owner manual to get support.
Posted on Feb 04, 2009
    Genius:
  • 1,913 Answers
Check your disaply mwenu settigns reset all settings to its factory defults then try.
Posted on Feb 03, 2009
  • 10,594 Answers
Please hook any amplifier or receiver at TV AUDIO OUT terminals at rear and check do you get sound of TV?
If yes, that means TV Amp Out chip is gone and need to be replaced.
and if there is no sound on TV audio out terminals / pins that shows TV has problem in Audio Processing circuit and related board will be replaced.
Thanks.
Posted on Jan 31, 2009
    President:
  • 2,559 Answers
When you push the volume up,Do you get a "Not available"message?
Or,Do you get the volume bar?
Posted on Jan 29, 2009
  • Randy Hough
    Randy Hough Feb 03, 2009
    Try this
    1. Press the MENU button to display the menu. Press the ▲(up) or ▼(down) button to select "Sound", then press the ENTER button.
    2. Press the (up)▲ or ▼(down) button to select "TV Speaker", then press the ENTER button.
    3. Press the (up)▲ or ▼(down) button to select ・"ON", then press the ENTER button.
    Press the EXIT button to exit.
    You can also reset all defaults
    Press and hold the EXIT button for a while. This will
    reset to the factory defaults
    If this doesn't fix it,The audio chip is bad.
    Sergeant:
    Champion:
  • 378 Answers
Did you try going through the setup menu to make sure you have the sound or speakers on? Also try connecting a headset to the headphone jack and see if you can hear anything. If you can hear sound through the headphones the speakers may be blown.
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
My samsung tv won't turn on , It just started to
Your Samsung LCD TV needs a new power supply. You can obtain one by part number from sites such as shopjimmy.com, discount-merchant.com or tristatemodule.com.
Apr 26, 2010 | Samsung LN46A650 46 in. LCD HDTV
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing that.it would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Samsung LN32A330 32 in. LCD TV Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
