Question about Nokia N72 Cellular Phone
Power Drain out early
My Mobile Nokia N72 2 years old developed one problem. The problem is it drain out the power with in 2-3 hrs, after full charging. During discharging the battery is also getting heated up. Please guide me to solv the problem.
Thanking you
    Problem Solver:
  • 8 Answers
Please check you battery, it might have a problem if it gets heated . This can damage your ears . Please change to a new battery to protect your phone and health.
Posted on Mar 18, 2009
Testimonial: "Thanks."
Asko dishwasher D1760 tripped the power on drain function, replaced drain pump then worked ok. Next day dishwasher started making a very loud noise when washing then tripped power. Thoughts?
The replacement pump may have failed early on. Something other than the pump may causing failure, such as ingestion of some kind of destructive material.
Feb 11, 2017 | Asko Dishwashers
Why doesn't it start?
How old is the gas in the tank? If it is older than 2 months drain it and put in fresh gas.
Feb 11, 2016 | Electrical Supplies
How do I drain the old gas out and clean the carburator
dissconnect the fuel line into the tank after the valve and drain it. you might want to put in a high octane when refueling also u can try a lil methyl hydrate
Oct 16, 2014 | All-Power America All Power 10000w Apg3090...
Power on after insert charging jack for a minutes plz solution my problem
charge it for a full day before trying to turn on
my nokia was left for 6 months drained... i left it to charge overnight, but to be sure try 24 hrs :-0
May 24, 2013 | Karbonn K9
Pulsating power drain
1/2 amp is just the computer drain. The rule is if it is not at least a 1 amp drain don't worry about it.
Sep 06, 2012 | 1986 Ford F 350
Drain is plugged on Frigidaire washer ATF6700FS2
vacuum at full power from both sides, this should pull the rags further apart, making it easier for the water to flush them.
Nov 15, 2011 | Frigidaire ATF6700FS Front Load Washer
Pontiac 2008 G5, battery just over year old, run car for an hour every other day to keep charged, frequently hard to start, clock resets, needs jumps, sometimes will start if it sits for 20 minutes. Was...
It is hard to confirm...as you are aware...your battery is draining when not running...First try turning off all power including the radio on your next shut off...If this does not work, The only drain is usually the starter has developed a short...replaced one...and fixed problem 100 %...(as long as everything else is properly shut down)...Hope this helps...nice car:)
Jan 03, 2011 | 2007 Pontiac G5 Gt Coupe
A couple weeks ago, after plugging my HP laptop back in after using it, I noticed that my battery did not start charging immediately. Since then, the power level in the battery has slowly been dropping...
Yes, you have come up with the right answer.
Most laptop batteries do well to last 1 year before they wear out. You have done very well to stretch out 3 years on this battery. Good work!
If you want some help finding a replacement battery, please reply with the full model number of the laptop and I'll track one down for you.
Thanks for using FixYa and Happy New Year!
Jan 03, 2011 | Computers & Internet
5 years - no problems, then started to ice up . Ice forms in the bottom and will develop 1 to 1 inch thick sheet in about 10 days
Check drain under freezer coils and clean out. Look out for frozen drain instead of trash Use hot water or turn off 24 hrs if that is the case. I usually insert a phillips screwdriver dowm in the drain and
pour hot water on the screwdriver so the heat transfers downm the screwdriver to the ice clog.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Maytag 15.6 cu. ft. Upright Freezer...
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Nokia N72 Cellular Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
