Question about Panasonic PT-47WX49 47" Rear Projection Television
Pt-47wx49e service mode
I need to know how to get into the service mode to try to realign the red convergence. I have been thru the setup menu and this does nothing. I turned the TV on yesterday and the red is all wacky. I open the back of the TV and place a sheet of paper over the red lens and it looks fine (except I get no red hue). How do I get into the service mode? I had a technician show me about 5 years ago but forgot. Help. Dave Email me dnovak12@comcast.net
  • David Novak Jul 27, 2007
    OK, Thank you.
    Now another question.
    I took apart the red lense to see if it was blocked. (Other than the 1/8 inch of dust on it) Stupidly I also removed the black bracket on the bottom of the lens. Water, or something like water, came out. I put everything back together but the liquid spilled on the circuit board. I have not yet plugged the TV back in. I am waiting for it to completely dry.
    How bad did I screw up? What can be done to fix this. I am such an idiot.
    Dave
    Problem Solver:
  • 6 Answers
It sounds like the convergence amplifier IC for the red crt is at fault. To check this, go into your user menu and pull up the red convergence. Try to move it up/down or side to side(it doesnt matter). If it moves up and down, then the vertical amp is working. Likewise if it moves side to side, then the horizontal part of the IC is working. If it dosen't move at all, or only moves up/down or side to side, then the IC is bad. There are 2 large IC's on the chassis, mounted to large heatsinks. They have STK392-110 or some variation of an STK392. If yow feel that the IC is bad, change the ic BEFORE you go into the service mode, as you wont need it if the ic is bad. To get into theservice mode: 1 make sure tv is in cable mode 2 set sleep timer to 30 minutes 3 tune to channel 124 4 use volume down on front of set to turn volume all the way down. ( writing will appear in the top left corner). 5 use remote control and press the power button. 6 the 7 button on the remote will put it convergence mode. Good Luck!
Posted on Jul 27, 2007
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Service manual for PT-47WX49E
i need the service manual as well, if possible (i'm just having a red horizontal convergence issue).
also, any advice on what to do would be swell!
my email is v6vywa002 [at] sneakemail [dot] com
thanks!!
Aug 17, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47wx49E
you have to go into service menu to reset convergence after changing ics.I never posted this because if you do not know how you can shut set down.which chassis do you have ? There is 3 diffenert ways to enter into service mode for convergence.
Apr 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Projection TV PT-47WX49E convergence ...
may not be convergence may be a bad stk for convergence if that style if so try stk
Oct 28, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Aug 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E - Convergence issue, need a service manual
HI Mike you will have to purchase that schematic at samsphotofact.com or repairworld.com they cost about $40.00.US.good luck.
Apr 26, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Service Manuals
scott iam in need of one too would you PLEASE add me to your list Thanks so much
Apr 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
249 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
