No water in Bosch WFLI2440GB/05
There is no water going into my Bosch WFLI2440GB/05 washing machine, regardless of which programme I choose. I have cleaned out the water inlet strainers, checked the tap and all seems fine. I can't hear any noise from the water inlet valve (is that the grey box thing attached to the hose near the tap), so I'm guessing this is faulty? If so, can I attempt to fix this myself? I'm no expert in this field, but willing to try!
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Error alert beep
I would suggest check your brushes on motor.if low, change them and reset the Machine.goodluck
Mar 11, 2013 | Washing Machines
Bosch WFLI2440GB/5 Washing Machine drain pump running continuously
Bosch WFLI2440GB/5 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 08, 2011 | Washing Machines
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
No Cold Water Wash; Only Hot
When doing a hot wash the machine is designed to take both hot and cold water. This is because it can heat the water to your selected temperature but if the water coming in is too hot it needs to cool it down to avoid heat damage to your laundry.
Hope this helps & thanks for using Fixya.
Dec 18, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Fitting washing machine boot gasket/door seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
May 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
