Question about Fisher Paykel EcoSmart GWL15
My Fisher & Paykel Washing Machine of two years won't turn on, all of a sudden. I unplugged and waited 1 minute...didn't help. I cleaned hose...didn't help. I don't see anything caught between inner and outer tub. Any other ideas?
  • Jim London
    Jim London May 11, 2010
    Hi, When you say won't turn on does that mean you have no indication of power? if so try plugging something else into the outlet and see if you might have tripped a circuit breaker.
  • 3 Answers
Sounds like main computer has gone, check for loose wires as the plug into the rear of the top removable panel
Posted on Feb 09, 2009
Service at number 37
Posted on Nov 08, 2010
Door won't open on my fisher and paykel washing machine and it is stuck on 1 minute
Unplug it for five minutes. Replug it and see if the condition changes or resets.
Feb 16, 2015 | Fisher and Paykel Washing Machines
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher paykel Washing machine stops spinning then resumes.
This sounds like it could be a faulty door lock switch. The switch can be tested for continuity using a multimeter. A lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Aug 05, 2009 | Washing Machines
Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Dec 06, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel intuitive code 37
As a serviceman for 18 years I have seen this numerous times.
The fault sounds like the motor control module.. Assuming your test on the pump windings was ok..?
Nov 12, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
541 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
