Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Drier Filter How do I clean it?
  • 333 Answers
There is one filter below the drum, but this for the water drain and there should be another filter another filter for the dryer there should be a filter between the drum and the exhaust hose for the hot air is. You should be able to pull this filter out for cleaning
Posted on Jan 29, 2009
How do i clean filter
check these out
Pump Filter - How do clean filter
Dryer condenser - https://www.youtube.com/watch?v=3L7ZB0bGs4o
Apr 15, 2016 | Washing Machines
Drier will keep stopping mid cycle with a filter led coming on...even though the filter is cleaned.
Experience shows that a fair percentage of fluff actually enters the body of the drier, and obstructs airflow. This causes the heater element to exceed safe temperatures, and a 'Filter' warning occurs.
Unplug the appliance, remove the rear cover, and remove what fluff you can, using a clean paintbrush to reach behind certain cover plates (etc.).
This should solve the problem.
Jun 08, 2011 | Dryers
My LG dryer says check filter but I've cleaned the wire filter and the lint that was trapped under the filter. It still says check filter. Is there another filter?
I relocated my drier and noticed the same light when I plugged it back in. The owner's manual states that the light comes on whenever the drier is turned on, to remind you to check the one and only lint screen.
Apr 17, 2011 | LG DLE5977 Electric Dryer
Helo I am muhammad iqbal i fill gas in unit after few mints its chowked i fix the new gas filter in out door unit and clean all gas systam out door unit also have problam
Dear Iqbal! Remove filter drier again. And flush out with Nitrogen. Now, Braze filter drier and then vacuum minimum 1 hour. Close valves and break the vacuum by charging little freon, say 80psi in ideal.
Run the unit and start gas charging till return good and back pressure 60 psi @ 98 degree ambient.
Now, the unit will survive for longer period further, provided servicing the unit periodically. Helpful?
Jan 06, 2011 | Mitsubishi MS17TN Air Conditioner
How to determine evaporator icing problem of air conditioning units
Due to :
1.. Evaparator coil dust blocked. 2. Air filter blocked. 3. Less rpm of fan motor. 4. Short of gas. 5.Filter drier chocked 6. Compressor less pumping.
To rectify:
1 & 2.Clean air filter and evaporator. 3. Replace fan capacitor. 4.Check for gas leak and recharge. 5. Replace new filter drier, vacumize and gas charge.
Dec 16, 2010 | Heating & Cooling
AC repair
If it is low in freon then recharging is the solution. Hot air blowing can be due to, as you have said, low freon, dirty condenser fins or blocked filter drier. Make sure condenser is clean. Use brush to loosen the lints and dusts then flush it with a pressure washer. Blocked filter drier must be replaced and so with the freon. You will know it when frost appear on one side of the filter.
Aug 23, 2009 | Whirlwind FH-778 Air Conditioner
No heat
make sure the drier vent is cleaned out of all the lint including under your filter screen in the drier all through the drier hose and out the vent to the outdoors
Apr 23, 2009 | GE Profile Prodigy DPSR513GA Dryer
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
244 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
