Question about Sewing Machines
I'm look for a use and care guide for Nicchi 4675
  • 124 Answers
Hi, thanks for letting me help you with this issue. Necchi Sewing machines are made in Italy and are represented by a company called Allyn International. Unfortunately, their policy is to handle all issues through local dealers, which would include getting user's manuals. I have, however located a company that lists owner's manuals for Necchi machines. Your specific model is not listed, however, if you scroll down to the bottom of this page that I reference here, you will see that they have others that they don't regularly stock. Just click on the "for other models" and it will provide further explanation. Here's the link:
http://www.sewingstyle.com/Necchi-Sewing-Manuals.html
If you found my assistance helpful, please rate my service accordingly. Thanks for using FixYa.
Posted on Jan 29, 2009
My turn wheel, is very tight, doesn't sew good When I try to sew, I have to guide my material, the wheel is so tight
You didn't tell us what machine you have, but if it's an older mechanical machine, it's probably seizing due to old oil that has dried out. Resist the temptation to try to run the machine until the problem is taken care of properly. You could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Dec 08, 2017 | Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Keep decorative stitch consistant
Be very careful to not push or pull at the fabric, and instead just guide the fabric without force and let the machine have control of the feed.
Jan 29, 2015 | Baby Lock Ellure
Manual
You'll have to mention Brand, Model Number etc to get the User Manual. Better, contact Dealer or Call Customer Care.
Mar 29, 2014 | Sewing Machines
I paid to have my Pfaff tiptronic 2020 cleaned and repaired back in April. Haven't touched it till now. Although their test fabric looks fine with threads doing what they're supposed to, it doesn't work...
Rethread your machine. More than likely it is your bobbin threading is not in the guides right. When you rethread pull on both threads to make sure everything is seated in the guides right. Study your machine manual carefully.
Sep 18, 2017 | Sewing Machines
I have a Nicchi Alco sewing machine that needs maintenance. Is there a business in/near Ocala FL that is knowledgeable about this brand?
I suggest that you go to the necchi website, it's allynint.com
call them & ask them or email them & see if there's a necchi repair shop in your area
Aug 10, 2011 | Necchi 3537 Mechanical Sewing Machine
Bird nest when trying to sew. Under material by bobbin - tried changing needle, bobbin. Tension - no change to the problem from Auto for regular sewing to 2 for embroidery
i think you have something catch on the tension guides. Try to clean out anything you can see and pull a thread towards the needle. I have done this with a small knot to snare anything but be gentle. Also, rethread carefully.
Try cleaning the bobbin case too
Sep 12, 2010 | Janome Memory Craft 9500 Computerized...
How to replace the thread cutting inside the machine
You could just call Brother customer service, and they may be able to guide you. The phone # 1-877-276-8437. You have a very nice machine so you don't want to have just anyone look at it, be careful who does. My sister learned the hard way. Good luck
Sep 10, 2010 | Brother SE-270D Computerized Sewing...
Bernina 1630 needle will not move go side to side.
If you can pull the needle bar down manually and it springs back up, the basting clutch is stuck. By someone who knows how, it's a very easy fix. I would guide you here, but I don't know how to explain it. Plus, you have to be very careful not to damage the spring loaded clutch.
Jan 02, 2010 | Tacsew 950
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Aug 24, 2009 | Necchi Sewing Machines
Sewing Machines Logo
63 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
