Question about Sharp AR-5316 Advanced Digital Imager Copier
BLINKING OF CH IN SHARP 5316 COPIER MACHINE - Sharp AR-5316 Advanced Digital Imager Copier
  • Anonymous Feb 03, 2009
    CH AS
  • eldorados7 Feb 03, 2009
    CH APPEARS AS SOON AS I START MY COPIER
1.check up the cover in the right side.
2. may be a toner cartridge problem
Posted on Jan 29, 2009
2 Suggested Answers
  • 109 Answers
SOURCE: Sharp -COPIERS - AR-5316 Advanced Digital Imager
You have an open door or the is no toner cartridge in the copier
Posted on Oct 28, 2011
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have CH Problem in sharp ar 5316 machine. How can I solve my problem?
CH - open cover in the paper feed area CH blinking - Dev unit is not properly installed For the 'CH' check the covers and make sure all covers are closed properly. For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly seated. The developer unit is the unit you slide your ink cartridge into.
May 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
Dears, i have electric problem in my machine SHARP copier AR 5316 it not printing showing (EH) i thing itis electric how can i resolve
CH: i think you mean CH , there is tow type of " CH:
  • blinking "CH" check the toner cartridge and reinstall it correctly
  • steady "CH" check the copier door and close it properly
thank you for using fixya
Mar 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
My copier is showing CH what do i do to it
CH are in two forms steady and blinking CH. Steady CH is associated with door switch for either front cover or side cover. Make sure that the front cover and the right side cover are closed properly.Secondly, Blinking CH
is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp AR016FT. Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
CH Error
CH - open cover in the paper feed area.OR - Sorter not installed properly
CH blinking - Dev unit is not properlyinstalled.
EE-EU - Low toner density in thedeveloper.
Check/ replace toner cart. Check/ reset Dev. unit. Check covers and doors to make sure all are closed properly. If you have sorter -- make sure sorter is seated properly.
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE AND BLINKING RED TRIAGULAR LIGHT POINTING TO TRAIL
Some part/ unit (developer, drum, imaging unit, fuser) or something else is not installed properly or is not plugged into the machine. Check all assemblies that can be removed from the copier, and make sure they are installed and plugged in properly.
The 'ch' code will automatically reset when the fault is found.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
