Question about Standard Horizon CP175C GPS Receiver
Antenna connection Have bought a new Ant. however no matching plug on Display , All wires between Ant. and Display match by colour except the Black from the Ant. and orange from Display. Is there a regular Ph. # i could call and talk to an expert at standard ? no 1=800 # please.. Is it pos. to change the 175C to a 175 and use the ant . with the coax Plug. My email is, fathershim @yahoo.com Thank you, Tony Shim.
Wiring diagram
It comes in the box you bought it with, and if you bought the wiring harness you just match the colors up, red is usually positive battery, black is ground, blue is antenna, white and blue is remote for your amplifier just he the manual out, I'm guessing you didn't buy a wiring harness or a antenna adapter
May 31, 2013 | Car Audio & Video
Very bad am radio reception, how do i fix?
If it's interference from the high tension wires,you probably need new spark plug wires with good resistor type plugs.
Now,also a bad antenna or a poor match of frequency to the antenna from the rec eiver can cause weak reception.Anyone who knows electronics can match the antenna to the receiver. don-ohio
Sep 14, 2011 | 2005 Dodge Magnum
Changing the factory stereo need the color coded wiring diagram
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
Jul 01, 2010 | 2001 Ford Mustang
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
I have just bought a 110/240v power pack for my laptop off Ebay from China,however it has the 3 pin European plug on,i have cut the plug off in order to change to a UK plug but the wire colours are as...
The grey is the grounding conductor which ties to the long pin.
Tie the one with the stripe to the neutral (wider pin)
Tie the black to the hot narrower pin.
Feb 08, 2010 | Dell Computers & Internet
Antenna bolt broke, how to fix antenna base.
This is probably way more information than you need, but here goes. I just had the same problem with my dads 2001 YUKON and wanted to put the stock wire back. It was not easy, but it can be done.
Remove the glove box, and plastic side panel on the dash
As you are looking through the removed area, there is a silver computer there, remove the bracket and move this computer.
Behind the computer there will be the plug in for the antenna. One side goes to the radio, the other to the fender.
Unplug the cable, and tape/fasten a length of wire to it so that when you pull it out, you have a guide to get the new wire back through the firewall.
Remove the old ant. and then take the guide wire and fasten to the new cable. Pull this guide wire through while someone else is feeding from the fender area.
Replug it, and reinstall the computer and glove box door.
Also, be aware and make sure that the new cable with stud matches the ant. mast. GM changed the size of the stud (for unknown reasons)and you may need to get a new matching mast. I could not use my old one
Dec 01, 2009 | 2001 Chevrolet Silverado 1500
Problem while matching CB
You need to understand how to tune an antenna and how the antenna works.
read this article
How to tune your antenna
and here is a list of causes for high SWR
Oct 28, 2009 | Cobra 29 LTD CB Radio
1991 Toyota Corolla wiring diagram
91 toyota corolla radio wiring
i checked 2 resources and they match , have you tries this schematic , see if you have a match to your cars wiring . actually this code matched corolla 88-92 , and also i checked all models of corolla and it matched , and from looking at the connector this is the order they are in
lt green
pink
grey
blue/yellow
blue
voilet
brown
red
black
white
yellow
looking at the connector , the only thing i don't see is the green illumination wire . if this is not a match , please comment back , what your wires are , and i will match them . thanks
J5
Jan 20, 2009 | 1991 Toyota Corolla
Replacing Clarion Radio cassette in 200 Impreza
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Sep 13, 2008 | Clarion ARX9270
Pioneer DEH-1100
Dont connect wires together randomly or you WILL damage the head unit. You need to get a multimeter. It will show you which wires have voltage and which wires are connected to speakers. I've found that old Pioneers have the same colour codes as new ones. So:- Black Chassis and negative. Red ACCessory switch (key) Yellow Constant 12v Orange Lighting Blue/white Auto antenna relay White Front left + White/black Front left - Gray Front right+ Gray/black Front right- Green Rear left + Green/black Rear left - Violet Rear right + Violet/black Rear right -
Apr 14, 2007 | Pioneer DEH-1100 CD Player
Standard Horizon CP175C GPS Receiver Logo
Top Standard Horizon GPS Experts
Steve
Steve
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
