Question about Whirlpool GB2SHDXP Bottom Freezer Refrigerator
Reversing the door on an LG fridge freezer
Hi, I need to reverse the fridge and freezer doors on our LG fridge freezer and unfortunately i've lost any documentation that I had. I've searched the LG website but it says to contact the service provider.
Any help would be really appreciated
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
  • 6 Answers
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
farfield
  • 462 Answers
SOURCE: removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Posted on Jun 27, 2009
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
milten1
  • 1304 Answers
SOURCE: Since reversing doors on my f 220 e fridge freezer
the only reAll reason, for this might be that when you reversered the doors you did not reseat the door gsaskets,
take a dollar bill and place it in the door go around the entire edge,make sure the gaskets are sitting properly, often when reversered the gasket have pinches that can and will allow hot humid air into a running unit.
if you do find a spot that the gaskt is just not sitting right,, most common is the corner of the new hinge
if its the production run im thinking of, check the freezer door top
anyway try warming it up witha hair dryer it will soften the gasket,,, and hopefullly allow it to reseat
Posted on Oct 30, 2009
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
Fridge not cold enough, freezer is. How to get the fridge colder?
If there is still ice in the freezer it will need to be completely defrosted for air to circulate through the coils. Make sure the fan is turning in the right direction. a generic fan motor may not be turning in the right direction and will need to be reversed by turning the armature around if this is possible with the replacement motor most universal motors are reversable and should show you how in the directions.
Oct 04, 2014 | Kenmore Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The fridge has lost power
hi here,
something might be wrong with the wiring that connects the power wire to the fridge. better have someone professional take a look at it as it's a delicate solution. Better yet, try plugging the fridge somewhere else, maybe your current plugging socket has problems.
May 18, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Lg electro cool fridge
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
Apr 08, 2008 | LG Refrigerators
Whirlpool GB2SHDXP Bottom Freezer Refrigerator Logo
593 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
