Question about Nokia N72 Cellular Phone
I m having display problem.
The display would come for a while then slant white lines will come
then screen is completely white..
i switched off the phone for 12 days then switched it on .
it worked properly for 2 days then again the same problem arose.
please help , i have nokia n72
  • 450 Answers
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Posted on May 12, 2010
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
I ran a new line for my dryer and instal;led a new breakewr in the panel wire the plug as such black wire to one slanted term the red to the other and white to the one in the middle straight one when i...
Black on one slant, white on other slant, red in the middle. Red and green are ground wires throughout electrical. Black and White are always hot and nuetral.
Aug 05, 2010 | Dryers
After 5-10 minutes screen turns completly red/orange
Hello Fixya customer,
Although it would be helpful to be model specific, I can point to some general areas of concern.
If the screen is turning red with White slanting lines, that is an indication of a faulty color dirve circuit or red CRT. Please supply the model number so that I may give you product specific information.
Thank you for using Fixya, and I look forward to your response.
May 01, 2010 | Sony KP-46WT500 46" Rear Projection...
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
My Sony Camera screen when i turn it on is white & has a pink line going diagonally through the screen
A multicolor vertical line may display on the camera LCD screen if there is glare on the subject being photographed. Avoid photographing very shiny surfaces that reflect excessive amount of light into the camera lens. Follow the procedure below to resolve this issue:
  1. Record the video or click the still pictures in a different lighting environment.
  2. On the camera, move the FOCUS AUTO/MANUAL switch to AUTO .
  3. Set the PLAY/STILL/MOVIE selector to MOVIE or STILL .
  4. Press the WHITE BALANCE button until the white balance is set to AUTO (no indicator).
  5. Record the video to new media.
  6. NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required.
Aug 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Lines on my display screen too.
More than likely you will need to replace the LCD screen. When it got wet, it probably damaged the LCD screen. Usually it justs blows them completely out.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is extremely easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the 580i LCD display and links to buy the screen.
Sony Ericsson W580i LCD Screen Replacement
I hope that helps you out
Jul 10, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
Nokia N72 Cellular Phone Logo
113 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
