Question about Technics SL-1210 Turntable
When i backspin the arm is forcing itself off the vinyl
Just got a 1210 and im completely new to this!! seems to be a problem with the weight? as soon as i lay the arm onto the vinyl it feels like its pushing its self off and when i backspin the record it just comes off??? really not sure why, it plays ok but just when i reverse the record it aint avin it??
  • Anonymous Feb 08, 2009
    the arm feels stiff needle sticks and slides back off vinal
  • Gerry Feb 08, 2009
    arm feels stiff needle sticks and slowly slides backwards
  • 4,234 Answers
1) make sure that you have the correct needle for backspinning. Standard needles touch the record at aslight angle, needles designed for backspining will be at a right angle to the record.
2) The tone arm needs to be balanced correctly as well. Based upon your description, the tonearm may be too light. I think that the standard weight is about 1.5 grams. There should be both a rough and fine adjustment available for balancing the tonearm. Set the fine adjustment to zero(0). Move the rough weight to balance the tonearm level. Then turn the dial to 1.5 grams. That should give you the proper weight at the needle.
Keep us posted.
Dan
Posted on Jan 29, 2009
    Problem Solver:
  • 16 Answers
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
1210 tone arm won't stay down. When I unscrew the
Check the point where the arm piviots, maybe a screw has come loose. Depending on the type of cartridge it should track at 3 to 4 grams.
Jun 08, 2011 | Technics Audio Players & Recorders
Hello, so for some reason the needle is sliding down the vinyl towards the center every time we go to play it. it just slides across! makes no sense, the needle is not broken and we have been trying to...
needles never seem to look broken But a tiny chip on them will make the player do exactly what your describing, as far as the counter weights,, spin the player by hand , click the handle to make the arm begin to position itself at the beginning of the record, Now, before it drops, slow down the hand spinning, and set the weight so that when the arm is supposed to drop it doesn't,, in other words balance it to be level, No up or down motion, without a weight scale to do this by the book, try this , Its always worked for me, tape 2 pennies to the weight at the rear of the arm, and one penny to the head of the arm, again, adjust it to be level,, then remove all the pennies,, the arm will have about the correct weight they require for the needle to be correct,, if it still slides, you have a bad needle
Jun 06, 2011 | Numark TT1510 Turntable
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
CD BACKSPIN
CD Mode does not react in the same manner as as Vinyl mode when you try to back spin. At the very least, you will only be able to go back a few bars. It's mainly used to set the Cue properly.
If you want it to back spin, you'll have to use the Vinyl mode.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 03, 2009 | Pioneer CDJ-800 Turntable
Technics 1210 tone arm Problem
This table should have an "anti-skate" adjustment. This is out of adjustment and putting to much tension on the arm. This adjustment is designed to insure that the needle tracks in the middle of the groove rather than one side. If the arm is out of balance and this os out of adjustment, the symptom you describe will occur. Hope this helps, Dan
Jun 08, 2009 | Technics SL-1210 Turntable
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
Technics skipping
hi fletch83.
this could be the tone arm bearings too tight,damaged or in need of a little oil.
i had a similar problem on my 1210, it kept jumping all the time,ruining my mixes! it turned out it was the bearings too tight.
unscrew the counter weight so that the arm hovers over the platter and move it to the centre with anti-skate on zero.
slowly turn the anti-skate round to three and the arm should move over to the arm rest smoothly,if it stops before the arm rest or isnt smooth theres your problem,loosen the bearing adjuster slightly and try the hover routine again until its as smooth as you can get it. it is possible,if the turntable has been transported without dust covers the bearings or the pin could be slightly damaged from knocks on the top of the tone arm assembly.
let me know how you get on or if you need any more help.
darren
Oct 10, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
216 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
