Question about Dual XD7600 CD Player
The face won't open
I've had my CD player since Christmas, and its never done this until this summer. Whenever I push the "Open" button, it beebs like normal, but it doesn't open. It used to open after the air conditioner was on, or windows were rolled down, but now it won't open at all. Is it because of the heat? And is there anyway of fixing it or is my CD player just done for?
  • arrick wiseman Jul 27, 2007
    I dont see anything, because i cannot pull the face out. I fear i may break it if i force it out. There is not a clicking noise, just the normal beeb.
    Thank you very much A13X, it wasnt gears, it was a bad connection problem. I had to push on the face to get a good connection and it opened. Now I have cleaned the connection points and it works fine. But thanks a lot.
    Problem Solver:
  • 9 Answers
Can you pull the face out? If there is no sound at all coming from the head unit (besides the beep) there's a good chance the gear motor that controls the movement of the face is stuck or burnt. Now if there's a clicking sound, the gears may skipping which can be wear'n tear or misaligned gears. I wouldn't call you player done for though. I would take it out, inspect the motorized face machanism and post what you see.
Posted on Jul 27, 2007
SOURCE:
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Brand new ASUS desktop DVD/CD R-W drive won't open.
hold the faceplate open, get a paper clip. There is a small hole in the front of the DVD/CD drive, place the paperclip in it and push slowly until the device drawer opens.
Jan 21, 2012 | ASUS Essentio Desktop with Intel Pentium...
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Face plate won't open far enough to insert a CD
try to hit slowly the faceplate in the left side until its open
Mar 08, 2008 | Pioneer DEH-P80MP CD Player
Flip Down faceplate is stuck.
I have the same problem, and all my problem was is that one of the wheels were out of place. You can see these white gears at the bottom left and right. Just stick something in there and push it back in place. It should just snap back in.
Mar 16, 2007 | Dual XD-7500 CD Player
Dual XD7600 CD Player Logo
270 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
