Question about Nokia 6600 fold Cellular Phone
Nokia 6600 Fold
Hi
I can't figure out how to remove the back cover so as to insert the sim and I don't want to force it in case I break it!!! I thought it was just me being stupid but no one at work can figure it out either.
Help!!!!!!!!!!!
  • 1 more comment
  • Anonymous Feb 18, 2009
    I have the same problem - did you figure it out??
  • Anonymous Feb 24, 2009
    I have passed my phoe around about 8 people in my office and no one can get it open. This is insane! I only got it two hours ago and am now already going off it.
  • Anonymous May 01, 2009
    Had exactly the same problem.As advised above gently click open flaps at side of camera.
Got it, Lift the two corners near the camera lense but a little (so that they pop free) then slide the cover down it should come off then
Cheers
Posted on Mar 26, 2009
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
Change fasciain nokia 6600 fold
Hi eugenemd,
1. Take front faceplate off by inserting credit card 1 between housing and silver key. As you pull up, take credit card 2 and slide it on the side of the phone prying the clips off.
2. Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen.
3. Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover.
4. That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
Please leave me comment, if you need further assistance
good luck with your fix,,,
have a nice day,,
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Mar 09, 2010 | Nokia 6600 fold Cellular Phone
How do i remove the keypad from a nokia 6600 fold?
  • Remove your back cover, battery, sim and memory card. Remove the six screws you can see.
  • Run something like a credit card under the keypad to release it.
  • With the keypad removed your phone should look like below. Remove the two screws you can see. Then pull the housing in the direction shown by the arrows to release the two clips that hold the circuit board in place.
  • The battery compartment should no be loose. Lift it away from the rest of the phone, as shown.
  • Your phone should now look like below. The circled connector needs to be disconnected. It attaches like a plug and socket. Just lever it up to unplug.
  • You can now lift the circuit board away from the rest of the phone.
  • Run your plastic tool all the way around the join of the front cover to release it.
  • Remove the part shown below. You can either pull it away with your fingernails or lever it off with something like a small flat head screwdriver.
  • You can now remove the front cover, as shown below.
  • The metal frame should also be loose and can be removed. Another ribbon connector needs to be unplugged like the one in the earlier stages of the guide.
  • You now need to slide your plastic tool under the screen. It'll be stuck down with double sided tape so a little force is required.
  • You should now have the LCD screen removed. Reverse the whole procedure for reassembly.
Feb 10, 2010 | Nokia 6600 fold Cellular Phone
How do you remove battery from Nokia 6600 fold phone please?
At the back panel of the phone you ll find cover and a sign to press and remove.
Oct 02, 2009 | Nokia 6600 fold Cellular Phone
Where do i have to insert the memory card in Nokia 6600?
Hi and welcome to FixYa,
The SD memory card is inserted underneath the battery below the SIM card. The same lock the holds the SIM card also locks the memory card.
Good luck and thank you for using FixYa.
Apr 09, 2009 | Nokia 6600
I want to change sim card in my nokia N72
Dear
I think u have some problem with removing back cover of ur phone
To change sim card follow below instruction
1) Turn off your mobile phone (press switch off button on top of the phone)
2) Remove back cover by pressing unlock button on the cover & slide cover upwards gently (please take care you would not force the camera cover)
3) Remove Battery From the phone & u will see ur current sim or sim slot
4) Check instruction & insert your sim
Thanks
Mar 30, 2009 | Nokia N72 Cellular Phone
Nokia 6600
problem for sim interface ic
Feb 25, 2008 | Nokia 6600
Nokia 6600 fold Cellular Phone Logo
557 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
