Question about Lenovo IdeaPad Y510 Notebook
The bottom case problem
My lap can't unfold clearly.
  • 479 Answers
HI,
This is the known issue with the Y510 so immediately contact the customer care and get it changed.
Posted on Jan 29, 2009
I need to print the lyrics to Beulah Land and When God Unfolds the Rose by Timothy Spell
"When God Unfolds the Rose" LYRICSThere've been times when I thought my prayers
Didn't even reach the ceiling of the room
Where I knelt to pray
And a voice inside kept asking me
Did I think God was really listening
To anything that I had to say
But I just kept on a praying
And holding on by faith
Knowing God is always in control
And I waited like a rose bud in the garden
For only God can unfold the rose
When God unfolds the rose
He always gets it right
When the petals are in place
Oh, it's such a beautiful sight
God knows when to hold on
And the perfect time to let go
So let God have his way
And watch God unfold the rose
There are trials and tribulations
We must all go through
When it comes to heartaches
We've all had our share
Oh, but when times are the hardest
We need to hold God to the promise
He said He'd never give us more than we could bear
So, I'll just keep on a praying
Knowing God is working all things for my good
And I'll wait just like that rose bud in the garden
Feb 27, 2017 | Rose Computers & Internet
My Colman furnace is not igniting. A one blink code (Ignition failure). What is wrong with it.
Clean the flame sensor and igniter , reseat all grounds.
clear the induced draft sensors tubing connector at the induced motor housing, the connecter plugs and is tough to clear, try a paper clip unfolded and ream it out well.
Apr 11, 2016 | Heating & Cooling
Ironman Quest Treadmill Unfolds Improperly
see the video and proceed according. God bless you
Jun 08, 2013 | Proform Exercise & Fitness
My power mirror wont unfold and makes a buzzizng noise
the gears in the mirror are worn either replace mirror or just live with it depending on how much they are to replace
Aug 25, 2012 | 2003 Lincoln Navigator
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
My Lap-top fan is allways on the full speed. Eaven when i've just turned it on. The fan actually causes the Lap-top to overheat. What should I do ??? My computer is Hp G7000.
There clearly is a problem with the air flow for cooling the radiator.
First, make sure you don't put your laptop on any soft surfaces, like your bed for example - soft underlay will press against the bottom of the case, obstructing the air intake grill.
Second, if it still happens on a hard surface (try placing the laptop on two pencils, to elevate it even more), then your air duct and the radiator itself may be clogged with dust and lint. You will need compressed air to blow away the stuff. Turn machine off, and blow into the air outlet grill, located on the side or rear of the case until all dust comes out.
Nov 29, 2009 | Computers & Internet
The heat on the left bottom of my dell lattitude d820 is a bit too much. How could I solve this? thanks
The first thing to do is clear out the vents on the computer. there should be one on the back and one on the bottom. these must remain clear of dust and other blockages. also make sure that when you use the laptop on your lap that you have something hard to put it on. I got a cheap laptop table from Ikea for like 5.00 and that really makes a difference.
Jul 30, 2009 | Computers & Internet
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Toshiba Satellite L15-S104 Gets VERY HOT
Make sure that there is good air flow all around the laptop, including the bottom. By resting it in your lap, you may be constricting the air flow. This is one of the reasons why laptops are now called notebooks! They really don't work well on your lap. When I use my notebook, I make sure that the fans have a clear path so that I don't have this problem. Try that and see if it works. You could also use a notebook cooler. They run about 20.00, depending on the type and size.
Feb 03, 2009 | Toshiba Satellite L15-S104 Notebook
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
Lenovo IdeaPad Y510 Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
