Question about Canon Office Equipment & Supplies
Faded prints off canon p100
Hi i just bought a new canon p100 printer, the prints are really faded and lacking in black, i changed cartridges and its still the same, what could be the problem?
  • 2,035 Answers
It could the problem with clogged print head try to clean the print head
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 29, 2009
Printing comes out faded and uneven
Printer heads clogged, do 4-5 cleaning cycles. If that does not fix it get a new printer.
Feb 20, 2014 | Epson Workforce 520 Printer
I am having trouble with my printer its a Lexmark Z605 Z600 Series I bought a new Black Cartridge16 and it wont print out clearly it come out very faded i had a 17 Black in before this one.Cheers Bev.
Are you sure your new cartridge compatible with your printer....
A faded print image is normally the result of one of three conditions: The printer is getting low on toner, the print density is set too low, or Economode printing is turned on.
If you need any kind of technical assistance then you can contact support cell at
Sep 05, 2012 | Lexmark Office Equipment & Supplies
Canon mp280 printing faded after replacing ink cartridge
Hi there, i have the same problem, did you find a solution?
Aug 20, 2012 | Canon PIXMA MP280 Multifunction Printer -...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
I cant print photos on a paper they look faded when i print them and when i print a leter or words it prints really well, the printer is a canon pixma you know what the problem might be ?
my canon mp250 won't print color photos it does well with BW but not color. I took back the first one I had did the same thing now the second one won't print color photos off the internet. what did I do wrong? Both inks are brand new.
Jan 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hello there, i have a canon MP370 which i have been very happy with and had no problems,however the machine when it prints now all the colours are very faded and banding occurs right accross...
Check your cartridge first and take a look if it is not running out of ink,try replacing it with a new one then on your printer maintenance do head cleaning,then print nozzle check to see which color has a problem,if it doesn't change try to look for chemical solution that are being use to clean print head. soak the print head,dont touch the head with your bare hands or anything hard its sensitive.
Sep 12, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Colour faded
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
70 people viewed this question
old marine
old marine
