Question about HP LaserJet 1012 Printer
Hp laserjet 1012 printer for mac OSX is continually "stopped"
Cannot get it to "resume printing". Has been working fine until now.
  • Anonymous Mar 27, 2009
    Tried reinstalling printer, driver software and disconnecting/reconnecting USB cable. Still says "Printer is currently offline" and no clue how to get it back online.
    Problem Solver:
  • 18 Answers
I dont use macs do i could not tell you have to manage the print queue but there is something you can try.
Take the power lead out of the printer and leave it out for 5 minutes and let the printers memory clear then re-send the print, it could a big print and the printer only has small memory so it could take awhile to process :)
Posted on Jan 29, 2009
My HP Laserjet 1012 stopped feeding paper, and my Mac printer dialogue box says: "the paper tray needs to be filled." It has paper. I have removed and replaced the paper several times, and opened up and...
The printer has a sensor that sees if the paper tray has paper in it, frequently by means of a finger that drops onto the surface of the paper. If this has been damaged, the problem you describe will be experienced.
Check to see if the sensor has been damaged.
Dec 10, 2013 | HP LaserJet 1012 Printer
The printer ignores the number of copies I want (1) and keeps printing more and more copies. It stops momentarily when I push the X button but resume as soon as I release it. The printer also stops when...
Presumably (since I had same problem) your Pinter is installed on an Apple Computer, possibly with OSX 10.8.
Upgrade to new HP Drivers dated July 2013 on HP Downloads site.
Michael
Mar 07, 2013 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
The HP laserjet 1012 printer has the online print status: "paused". I click resume and it goes back to pause. How do I troubleshoot this? The printer is on a shared network.
load the drivers in another system locally..check..if problem solved un install the divers reconnect & check..
If problem presists replace formatter..
Sep 06, 2011 | HP LaserJet 1012 Printer
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
Can't get this printer to work with the Mac
Hi
It seems that its a software Drivers issue
Drivers for MAC HP Laser Jet 1012
Click on the above link and download the software drivers and check the Print
Regards
Tx.
Mar 01, 2010 | HP LaserJet 1012 Printer
When i send a file to print from my mac (OSX 10.4.11) i get the error message in the printer box ''Printer not responding''I am using the HP 2500 Color LaserJet printer. It was working fine and just...
Connect the computer via fire wire to another working one.. and remove the two sleep files. Start your MBP holding down the T key The issue is a corrupt sleep file. once deleted your computer will work perfectly
Nov 11, 2009 | HP Color LaserJet 2500L Laser Printer, up...
Print SelfTest page
It should be able to print one:
1: try pressing and holding the button for 4+ seconds
2: power off ... press and hold the button while powering on and wait until it prints the test page.
Hope this helps!
Jan 15, 2009 | HP LaserJet 1012 Printer
Work with Leopard?
Apparently, with Leopard, you should be able to just plug in your USB cable and it will register. Go to Settings, then Print/Fax and click on the Add button. Make sure that the USB cable is attached securely both at the printer and the computer. I struggled with this for at least two hours, before my husband came home to fix it and it just worked. Very annoying.
May 01, 2008 | HP LaserJet 1012 Printer
HP LaserJet P2015dn
sounds like you're dealing with Postscript issues here. Does your HP have postscript drivers installed.
you might want to check on the current Mac drivers through this link
Mar 08, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 1012 Printer Logo
149 people viewed this question
Seeker5211
Seeker5211
