Question about Compaq Presario Notebook
Shaky screen my screen jumps alot while i'm using it, how should i resolve it thank y ou
  • oneputtjo May 11, 2010
    More discription of jumping please?
Shaky screen iphone
Hi Mike,
If your screen is shaky on your iPhone, this is probably due to a failed LCD. I recommend checking into getting it repaired with a replacement screen. PhoneDoctors.com is a good place to start. They are very reliable. :)
Sep 06, 2013 | Audio Players & Recorders
Tip
Rought or shaky idle
If you have a rough or shaky idle, the problem could be the air intake is dirty. You will need to get to the butterly of the air intake and clean it out. There is a cleaner that is sold for about $5. Use a screwdriver to help keep open the butterfly. Spray the cleaner and use a dry cloth to clean the inside of the intake. This will help to clean up alot of the gunk in and around the intake. When you first start it up it still may have a rough idle for about 20 to 30 second but it will go away. There may be even a little smoke of the exhaust but will clear up. You will have a great idle again. Great day.
on Jan 29, 2010 | Chevrolet Silverado Cars & Trucks
I just bought a used Toshiba Tecra M3. I'm having issues with the video on the screen, grainy, shaky with lines then it goes dim and black
Try to reseat the video card and re-install the video driver. If it is still grainy or shaky, try to blow pressurized air into the pci-e slot where you connect the video card then re-install the driver.
Jun 09, 2010 | Toshiba (K000823110) Motherboard
How to Change NTSC/Pal ?
press the button again
or try taking out the
DVD
Jan 10, 2010 | Televison & Video
On screen cursor shaky
You need to go to system panel and adjust the sensitivity settings. Try that and hopefully that will resolve the issue. Good luck!
Nov 06, 2009 | Nintendo Wii Console
Last castle on level 6
Level 6, final castle is the one with the elevator right?
A friend of mine said you should use a giant mushroom but since you could only use it once, he said to eaer use it as the elevator takes you up or when fighting the boss. He said to do that thing where y ou jump up and do the ground slam onto the boss as giant mario. I haven't tried it myself but he said it worked very well.
Mar 08, 2009 | Nintendo New Super Mario Bros. for DS
Anyone know why the picture would shake slightly
Does this tv have hdmi input and if so does the problem exist there?
If so I suspect the av input board could have a problem.
Mar 03, 2009 | RCA HD52W58 52" TV
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Shaky screen
Many reasons can cause this mate... One try moving all electronics from around the screen like speakers, mobile phones etc... Then if it's still shaking then try lowering your screen resolution... right click on any free space on your desktop n select Properties. In the properties window click the Settings Tab n in the Settings tab drag the resolution slider back a level... hopefully this will resolve your issue... If it still does not work then you may need to update the drivers of your video card...
Post if the problem persists :-)
Feb 11, 2009 | LG Flatron Ez T710BH 17" CRT Monitor
Shaky hand symbol and bad quality photos
good day,
to disable/enable the "shaky hand" symbol of your camera, just select the Picture Stabilization icon on the dial on top of the FinePix F30.
i hope this helps.
Oct 12, 2008 | Fuji FinePix F30 Digital Camera
Compaq Presario Notebook Logo
430 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
