Question about Mitsubishi MS15TN Air Conditioner
Mitsubishi electric or Mitsubishi Heavy Industries
I want to buy a mitsubishi 5kW inverter air con but I don't know what to choose: mitsubishi electric or mitsubishi heavy industries. Can you help me with your advice.
  • vikey6174 Mar 17, 2009
    which company is more realiable for long period and all support
    if i m in asia
    Mitsubishi electric or Mitsubishi Heavy industries for airconditioners
    New Friend:
  • 7 Answers
As an refrigeration engineer dealing whit them every day my advise is: mitsi heavy industry away much more reliable and better performing.
Posted on Jun 27, 2009
I would sugest you to go for Mitsubishi Heavy Industries as there are many Features in Air conditioners. & for sure the support will be very good.
Posted on Apr 16, 2009
Go for Mitsubishi Heavy Industries
Posted on May 08, 2010
I had a similar problem. Have two mates who install aicons. Both said. Mitsubishi electric or Daikin are best in the business. Mitsubishi Heavy Industries not so good.
Posted on Jun 19, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have a Mitsubishi tv my balance fail what can I do
Posted on Dec 01, 2015
    New Friend:
I own a store where I trade both MHI and MElectric and most of my clients prefer and buy Heavy Industries although it might be 5%-7% more expensive.
Posted on Apr 26, 2013
Hi I need manual for mitsabishi heavy industries model no src7zea-s
Mitsubishi Link HERE:....https://www.mhi-mth.co.jp/en/products/detail/air-conditioner_users_manual.html
May 11, 2017 | Sewing Machines
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
What costs less Dry Mode or Cool Mode on an Inverter Unit?
Use Dry Mode. Saves on ur bill and cools just fine.
Jul 03, 2012 | Mitsubishi Heating & Cooling
Hi just wanting to know what the icons mean on my air-con for hot and cold
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 18, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What thickness of cable is required to the power point for a Mitsubishi MSWZGA71KIT is it 2.5mm or 6mm?
20 amps for every 5kw or 1amp for every 100 watts here is a simple wire size calculator http://www.gorhamschaffler.com/wire_size_calculator.html you can find amp draw and phase on the manufacters data plate on the side of the unit .
Nov 15, 2010 | Mitsubishi MSZ-A15NA Split System Air...
No Mitsubishi Air Con Manual
ok heres the problem. The a/c filter is clogged or the evaporator coil is clogged. These systems have a metering device that measures the amount of air flow over the coil. If this air flow is obstructed the filter light will flash. If the filter in the unit is clean then the coil has some type of obstruction. This will mean having to clean the coil before the light will go off. An a/c tech should be able to clean this for you and it not be a huge cost. They have the chemicals to get the job done fast and clean.
Change your filter first.
Good Luck hope this helped you some
Dave
Jan 12, 2010 | Mitsubishi MS15TN Air Conditioner
Fan roller and grey fins clogged with dust and mould
You can clean Blower wheel one of two ways. !st would be to remove the wheel and clean with the garden hose or if that is not a option for you then you can buy a can of compressed air and clean it that way but you will get a blast of dust and dirt when unit turns on. Make sure unit and/or power is of when doing this. Keeping your filter mainteneced more often will reduce the build up more.
Feb 15, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi heavy industries a\c srk20zcx-s
Most of the time once every season so once a year same time you clean the filters. But being thats its the cheaper chinese made heavy industries and not the better quality japanese made mitsubishi electric i would say once every 3-6 months
Mar 06, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Mitsubishi MS15TN Air Conditioner Logo
5,215 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
