Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Coffee grnder not working
I have a saeco expresso machine which is automatic but the coffee grinder does not work .Can i buy spare parts for the machine in australia
  • 515 Answers
Try to cantact Saeco Australia ( www.saeco.au), or Saeco Italy (www.saeco.it).
They should know where you can get spare parts.
Best regards
/Mirran
Posted on Jan 29, 2009
I set the grind control know on the lowest number to try to get a fine grind, but I still get a coarse grind which does not give me a good expresso, and the water runs fast. What else can I do it is a...
Hi
More than likley you grinder has become seperated internally. You either need to disassemble the grinder completely, clean it and then try to reconnect the pieces or just replace the grinder. I have some. Just let me know, new or used reconditioned.
Jan 02, 2011 | Starbucks Saeco Italia Digital Barista...
Hi - the machine works fine except that it leaks into the drip tray and kicks beans out, sometimes onto the floor. I have lots of tools and feel good about taking it apart, but need to know what parts...
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Sep 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
The coffe grinder smell burn after usage. Is there a way to clean it.
You should check you manual for directions as to how to take the machine apart to clean it because it needs regular cleaning. Since you have not cleaned it in a while, the beans are probably getting super hot and burning inside the grinder because of friction. Also, this particular machine operates best with a drier (less oily)coffee bean... think Italian expresso beans. These drier beans should work better with this machine.
Mar 04, 2010 | Saeco Easy Espresso Machine
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Grinder does not work
I have the spare part number to the grinder.
0301.R01.00A 230V
0301.R001.00F 100V
Hope this will help you.
Jul 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto expresso machine is producing thin, watery and cold coffee. I have walked through some troubleshooting with a Saeco rep and no better results. The top warming plate stays hot. Water flows...
It sounds like the heatingellement of the boiler is broken.Pump works. you also , if i am right get no hot water if you try that.
You can get the part on line. which will be cheaper than doing it through saeco
Try this link SAECO PARTS
Placing it is not too hard as long as you work methodical.
Apr 28, 2008 | Saeco Incanto Classic Espresso Machine
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Saeco vienna superautomatica
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water but no coffee
Your grinder needs cleaning- are you using oily beans and/or storing beans in refrig/freezer. Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out.. After celaning grinder, will need to re-set it.
Jan 15, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
662 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
