Question about Tomtom ONE GPS Receiver
Lack of Battery
I have a Tomtom one, and the battery seems to be dying alot, even wen plugged into the cigarette socket. went to halfords where i got the tomtom, and they said i had to contact tomtom itself to sort the problem out...neways, no luck with the company, and i basically need to knw where i can get a new battery for this model tomtom, in order for my satnav to actually work...
Cheers
J Griffiths
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
First make sure it is your battery. Check to see if when you are charging your device and wiggle the USB cable a little if the green charge light starts blinking. If it starts blinking on and off you have a loose USB connector. This is an easy fix if you have some soldering skills. Your device should not turn off when it is hooked up to power even if you have a dead battery.
Posted on May 04, 2009
Unlocking the car
You can either buy or easily make from readily accessible parts the "battery clips/clamps to cigarette lighter adapter" or just get a cheap chinese battery charger that has the cigarette lighter thing already attached to it. Plug one of these into the cigarette lighter for at least a few hours and it will charge the battery at least enough to unlock doors, etc.
If you are in some kind of metro area go to the Harbor Freight store and for under $15 you'll be OK. It is likely not the alarm system from preventing the hood being opened, but the lack of any electric power to kick the linear actuator from closed to open. Even still, once the battery is charged up again the alarm system would now be functional and you'd be able to turn it off or maybe put it in stand-by mode.
Nov 17, 2017 | 1988-1989 911 Carrera Relay Alarm
Tip
TomTom XL 330 not coming on?
If you TomTom is not coming on after a long sleep.. I.E. more then a few days with no use, try this......
(1) Plug the unit into either a PC or your Car
(2) Wait for about 2-5 minutes to get some charge into the unit
(3) Press and hold the power button for about 15-20 seconds until you see the start-up screen
Why did it die? I have found and many other have found the battery does not live long without a power supply to charge it, it would seem to me even thou it is powered off, the TomTom is still sucking away at the battery and it would seem there is nothing that can be done about it.
on Sep 16, 2009 | Tomtom XL 330 Car GPS Receiver
I have just bought tomtom via 160. I was told at the shopt that I have first to charge the battery for 5-6 hours. I've plugged the lead into a USB post in my computer but nothing seems to be happening....
Plug the power cord into the cigarett plug on you next ride
power the tomtom up after 5 mins
leave it on there for an hour
then at home plug the USB but also the tomtom
that should do it
cheers
rene
ps add kudo's if it helped
May 28, 2011 | Tomtom GPS
Hello. I have a problem that no one has seemed to be able to help me with. All i get is a dumbfounded look or scratch on the head. I have a Garmin Nuvi 780 GPS for the car. I do not have a cigarette...
Hi JoAnn, What you really need is a cigarette lighter socket in your car and this doesn't have to be a big problem. In most car accessory shops you can get cigarette lighter socket splitters, like the one at http://www.amazon.co.uk/Silverline-Cigarette-Lighter-Splitter-Adaptor/dp/B003TNYK7Y/ref=sr_1_1?ie=UTF8&qid=1301407423&sr=8-1
Now I know these are supposed to plug into your cigarette lighter socket but you can remove the plug from the end of it and get wired directly to the fuse board of your car. The wire that goes to the centre tip of the plug connects to the positive/fuse of the fuse board and the wire that's connected to the outer part of the plug connects directly to an unpainted metal part of the car. You can do this by loosening a bolt, wrapping the wire around it and tightening it again. The block with the sockets on it can be either glued with double sided tape to a convenient part of your car interior or left loose if you prefer.
If you're not happy wiring it directly yourself it should not cost a lot to get done in a garage. If I was in your position that's what I'd do.
Mar 28, 2011 | Garmin Nuvi 780 4.4 in. Car GPS Receiver
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
Have tom tom for car,need to wire it up to m/cycle
I've wired my tom tom for use on a motor bike.
you CANT run 12v straight into the tomtom, you can see on the cig lighter plug it has a 5v output.
So I bought cheap lighter socket, it looks like plastic tube with the cable running out of the back.
So the wires run from the battery (via an in line fuse) to the cig adaptors, these are hidden in my side luggage bag to keep dry and up to the tomtom. job done
Apr 20, 2009 | Tomtom ONE 3rd Edition GPS
Battery dead; cannot open hood
If the cigarette lighter is an unswitched power point you could use it as a location to put a very small charge, just enough to get the hood release solenoid to activate. Years ago there was a device that was a male cigarette lighter power point at both ends and enough cable to go from car to car. DO NOT ATTEMPT TO DO ANYTHING ELSE EXCEPT OPEN HOOD, DO NOT TURN KEY TO RUN OR ATTEMPT TO START. ANYTHING COULD RESULT. MINOR OR MAJOR. THERE IS A COMPUTER MEMORY SAVER THAT MATES A 9 VOLT TO A MALE CIGARETTE LIGHTER PLUG THIS MAY NOT BE ENOUGH TO RELEASE HOOD BUT MAYBE WITH A 12 VOLT FLASHLIGHT BATTERY (2 6 VOLT BATTERIES) WOULD WORK TO OPEN THE HOOD. (TURN EVERYTHING OFF EVEN DOME LIGHT.)
Aug 23, 2008 | 1999 Porsche Boxster
Tomtom GO 910
Check your battery symbol.
On mine, the battery is dead (or mechanically disconneced inside).
You need to reset the unit by pressing the tiny button on the back.
Problem is that when you remove the unit from the charging stand, the dead battery does not allow you to press the reset button. (Pressing the reset button with no battery cannot reset the unit)
IF you could press the reset button while plugged into the charger, you could get you unit working again. But..alas, the design of the unit prohibits you from doing so.
Chances are if you fix the battery problem, you will have a usable unit again.
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
