Dell Inspiron 6400 PC Notebook
Problem for Dell Inspiron 6400 PC Notebook
Ip Address 169.x.x.x Wireless Internet Connection Problems 6400/E1505 Dell Laptop
By swimwca on Jul 26, 2007
Whenever I try to connect I receive a 169.x.x.x
Info:
Intel 3945 ABG Card
Dell Inspiron E1505
Linksys WRT54G
Using Intel Proset Wirelessly to connect.
Tried unplugging the router.
Tried ipconfig /release and ipconfig /renew
Tried installing Intel Proset's newest software and driver. I restarted my computer and started proset. The UI was flashing rapidly and my cursor turned into a hourglass whenever it hovered over it. <-----I am extremely confused by that so I system restored to my old driver and software.
DHCP Service is enabled.
Other computers in network are working fine. (2)
I can connect to the internet using a cable.
Intel Proset/Wireless says I am connected with Excellent signal quality, however windows says I have limited or no connectivity.
I am guessing that it is a driver/software problem but then there is the dilemma when I install the new Proset software/driver. Thanks for the help in advance.
Comments:
Jul 26, 2007
- I think my WEP is connected properly.
Lazyboy could you clairfy what you mean?
I need to click on the network and click "connect" to connect to it if that is what you mean.
Thanks for the help guys :)
Jul 26, 2007
- Hmm. I tried assigning the ip but now Pro/Set wireless says that "Another application is controlling the wireless adapter.
Jul 26, 2007
- I can connect to another router in my area so I think it may be the WEP thing. To confirm I re-entered a bogus password and it said that I was connected to it. Now I have to find the pass from the admin.
Jul 26, 2007
- Hmmm. Currently, I can't connect to the router properly without the pass. I will ask the Admin (my dad haha) when he comes home from work for the pass. I am pretty sure this problem is as good as solved. Thanks a BUNCH! I have been trying to solve this for 2 days.
Best Solution
posted on Jul 26, 2007
Very Helpful)
sandrew
Rank: Wiz  Dell Expert
Rating: 83%, 5982 votes
when you renewed the ip address, windows assigns an ip address of 169.xxx.x.x, this your router will not be able to see.
if you have enabled dhcp in the router, check that the wireless card is set to obtain an ip address automatically.
If you have no luck that way, go to another pc and in the network card properties, look at the assigned ip address number that the router has given the pc, eg 192.168.2.2, if you have more than two pc you can bet that the other number assign wil be 192.168.2.3, so go to the problem pc's network card problem and and set the ip address manually to eg 192.168.2.4 and set the dns address to 255.255.255.0, save settings and try connecting again.
the only other thing stopping a conection would be if the security, eg wep or wpa is enabled and the number has not been entered correctly into the network card properties.
Comments:
Jul 26, 2007
- try using the wireless without the wep enabled, but what lazyboy means is, when you right click on the network icon in the taskbar you can select the option to view all connections and in the next window there should be a list of all the available connections in your immediate area, see if yours is there if so click on it then then choose connect automatically, but automatic or manual your router should still allocate the address, you should see a list of all the address allocated in the routers settings under 'DHCP clients' or a similair wording
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Helpful)
lazyboy321
Rank: Apprentice
Rating: 79%, 10 votes
when you search for available networks does the network state manual or automatic mine was set to manual and therefore was not allocating IP address automatically.
Was this helpful?
Yes
No
Solution #3
posted on Aug 02, 2007
Helpful)
hardrider54
Rank: Apprentice
Rating: 85%, 1 votes
the 169.x.x.x ip is set by Microsoft Operating systems when it cannot get a dhcp address. Try power cycling the modem, router and pc. Always bring them back online, modem first, router then laptop. good Luck
rider_
Was this helpful?
Yes
No
Solution #4
posted on Nov 06, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check for other software controlling your network card (versus the indigenous Windows software). Most computers come loaded with add-on software that often conflicts with Windows (and takes control).
Other folks have already noted...169.x.x.x is the operating system way of telling you that your dynamically allocated IP address is not available and has defaulted to the 169.x.x.x
Solution #5
posted on Feb 21, 2008
Somewhat Helpful)
BEEDU
Rank: Master
Rating: 82%, 27 votes
try allocating IP sdderess automatically.. might be ur IP adress in conflicting...
Was this helpful?
Yes
No
Solution #6
posted on Feb 05, 2008
Somewhat Helpful)
Kriz_121083
Rank: Apprentice
Rating: 75%, 1 votes
I suggest you do the ff.
1. go to Start
2. go to control panel
3. go to netwotk connection
4. right click local area connection, go to properties
5. under general tab..click configure
5. then go to advance tab... then under properties try to locate if you gave duplex word there
6. set it to duplex, then change the speed to 10 full mbps
normally that will able your etgernet adapter to get the Ip address that your modem or router is passing.
Was this helpful?
Yes
No
Solution #7
posted on Aug 25, 2007
Somewhat Helpful)
Tom Smith
Rank: Wiz
Rating: 83%, 98 votes
You can always hard reset it, by not asking your dad by taking a pen and sticking it in the reset section, and waiting for 30 seconds, then unplug for 30 seconds and then stick the pen back in again for 5 seconds and password will be reset.
Was this helpful?
Yes
No
Solution #8
posted on Sep 04, 2009
Not Rated)
nirpal_sande
Rank: Apprentice
Rating: 0%, 0 votes
guys i have the similat problem
can anyone help
Was this helpful?
Yes
No
Solution #9
posted on Jul 06, 2009
Not Rated)
dreamsayer
Rank: Apprentice
Rating: 0%, 0 votes
well.. if you want to use windows default program instead of intel proset then go to network connections then go to the properties of wireless network, go to the tab wireless network, check windows to configure my settings and then click ok... i hope that will solve your problem..
if you having problem with your ip.. try uninstall and reinstalling your network card drivers.. i am not sure if it gonna work, but you can give it a try..
dreamsayer@ej.am
Was this helpful?
Yes
No
Solution #10
posted on Jun 21, 2008
Not Rated)
funkyard
Rank: Apprentice
Rating: 0%, 0 votes
Yes a 169.x.x.x IP is a Windows Default IP and if not fixed...The operating system restore (system restore) or fresh installation can only be the last option.
Was this helpful?
Yes
No
Popular Solutions for Dell Inspiron 6400 PC Notebook
Questions and Unsolved Problems for Dell Inspiron 6400 PC Notebook
Do you recommend Dell Inspiron 6400 PC Notebook?
Answer
Answer
invalid configuration information- please run setup program &amp; do not enter setup
Answer
My laptop switches off, doesn't reboot or restarts. It seems to happen when i hit some of the keys... (More)
Answer
Dell Insperion M1540 Dell wireless broadband card is disables. Slide the on/off switch to enable it.... (More)
Answer
my laptop will not except the produce keys
Answer
My employer gave me a Dell 6400 Latitude Laptop to use at home through a VPN connection. I have a... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
