Question about Epson Stylus C46 InkJet Printer
Hi there, my printer is saying it doesn't recognise ink cartridges,so i've just changed them, and it still isn't reading them... help?
  • Anonymous Mar 14, 2009
    my printer is x5330 lexmark and i have bought the correct cartridges and it doesn`t recognise them
  • 353 Answers
Are these genuine Epson cartridges or clones? If clones, have you used this particular type before? Put your old cartridges in (that used to work) - are they recognised. If so, you have a dodgy set of cartridges. If not, you have a more serious problem. Remove the ink cartridges and look inside the carrier - do the contact pins that contact the cartridge chip look intact and undamaged. Check the narrow ribbon cable that runs along the left side of the carrier along the bottom has not come out of its connector. Check that the large ribbon cable that goes from the left side of the carrier to the main board has not come adrift. Report back.
Posted on Jan 31, 2009
shaky120
  • 310 Answers
SOURCE: compatible ink
Hi, sounds like a faulty ink cartridge, we get this now and again with selling compatible ink cartridges i suggest taking it back to the shop for a replacement wont be the printer as long as its fitted correctly with label removed..
Happy New Year
John
Posted on Jan 01, 2008
  • 461 Answers
SOURCE: HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
Posted on Nov 28, 2008
Grubhead
  • 5259 Answers
SOURCE: Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Posted on Apr 12, 2009
ghassun
  • 499 Answers
SOURCE: how to reset lexmark36 ink cartridge
try to reset ur printer
press and hold on power button for about 20 sec then press hte power button again
Posted on Jul 25, 2009
cns assoc
  • 677 Answers
SOURCE: Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "Thanks for your help. I have started using generic cartridges as I did with my Canon for years. Your help is much appreciated."
My stylus offive t40w printer wont recognise new ink cartridges
epson have these problem common. you have to wash cartriges contact points by aerosol.
May 29, 2012 | Epson Office Equipment & Supplies
Hi, I am trying to remove ink cartridge, but when I unclip it it doesn't come out, please help!
Hi.
Click Start>control panel>printers and faxes>right click icon of printer >select properties>maintenance
In maintenance you can read there "How to change ink cartridge" just screen instruction.
Jun 18, 2011 | Canon SELPHY CP720 Printer
I've got a HP C4780 printer which I have had for around a year but only used about 5 or 6 times! Despite the ink cartridges having ink in them, the black cartridge is not printing at all. Not even a...
The ink solidifies right behind the micro printing nozzles. The only way to attempt to rectify this is to dip the print face into some warm (not hot) water for a minute or two, and dry after wards. If the cartridge recovers, Yippee, if it doesn't, replace.
Common problem. Be thankful it isn't a Canon or Epson, which entails replacing a seriously expensive 'print head'.
Jun 08, 2011 | HP PS C4780 All in One InkJet Printer
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Epson cx8400 can`t recognise the ink cartridge!!!
If you mean you have a chip resetter and have reset the chip when you say you've "shock the ink cartridge" then it sounds like the chip on the cartridge is damaged and can no longer be reset. To fix the problem you either need to get a replacement chip or a new cartridge.
Jul 17, 2009 | Epson Stylus CX4800 All-In-One InkJet...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Jan 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink in hp photosmart 3310
the printer should have software installed enabling you to opt, for a printer-ink cartridge change.
If the cartridge has a chip fitted, it may be discharged.
The chip is supposed to be charged up, for the printer to recognise the newly installed cartridge.
view your settings in control panel/printer/properties to see what options you have available.
Mike @ Compurepair.
Jul 23, 2008 | HP Photosmart 3310 Printer
Lexmark P315 InkJet Photo Printer Ink Cartridge Problem
Hi, I know this might sound really bad but have you made sure that you have taken ALL the little bits of plastic and covers that are sometimes on the new cartidges?
Also are you using the exact same cartridge as before?
Another thing you could do to bypass the problem is to have your one refilled. That will at least fix the problem for the immediate.
Does your printer have some software where you can run a clean print head and do an align and other stuff. If so you could try those too.
Lets us know.
Oct 25, 2007 | Lexmark P315 InkJet Photo Printer
Epson Stylus C46 InkJet Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
