Question about Epson (1023661) Projector Lamp for PowerLite ELP-3000, 330
ELP 3300 lamp problem?
After the projector is on & is showing the computer desktop, the lamp will begin to alternate between on and off. This will continue until I turn off the projector. Is the bulb going bad. I looked at the manual and am going to clean the air filter next & check the status lights now that I found the manual on line.
  • 62 Answers
Probably. try to check the number of light hours( you can check the manual on how to view it) usually 10000 hours could mean that you need to replace the bulb. also check the physical appearance of the bulb, if it has cracks on the ceramic at the back, then you need to replace it.
Posted on Mar 29, 2009
The clock has reverted back to summer time how can I change the time
you can adjust the clock on the Menu
when you turn on the projector
Nov 02, 2014 | Epson ELP LP52 - projector lamp
Se ve borroso que debo cambiar la lampara o que
Original lamp USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jul 13, 2012 | Epson Replacement Lamp Projector Lamp For...
How to reset the lamp counter for Toshiba ELP-X3000 model after repalcing the lamp
Hi
Go into the menu.
GOto status in there you should find the lamp timer reset.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Toshiba TLP-X3000 LCD Projector
Epson ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp is fault,and other parts is working well
Have a nice day!
wheel,
Lampdeng Limited
Jerry
May 15, 2010 | Epson Replacement Lamp Projector Lamp For...
EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
EPSON EMP 3000
There is an adjustment in the Video section for adjusting it to look square.
Aug 13, 2008 | Epson ELPSC07 for PowerLite Home 10,...
Epson ELP-3300 powers up bulb light is green but...
Ah ok , so it doesn't start up at all.
Is there any power at all on the unit , like LED's lighting up ?
If there is then it would be your Ballast ( lamp's powersupply ) that need replacement.
If there isn't - then you should check on the Powersupply Board ( where your AC inlet sits in ) if the fuse is blown and if not , then you will have to replace the Powersupply Board.
Apr 22, 2008 | Office Equipment & Supplies
Epson ELP-3300 powers up bulb light is green but stays on stand by
Hi djSilver
Try resetting the lamp timer.
This normally solves this problem.
Epson elp 7200 projector
check power supply (electricity)in wall outlet by another appliance.
--check for defective power cord-test with another one.
=apply good brand of contact cleaner over power switch.and press it many times.
--check blown power fuse and change it with same rate if it is defective.--if all above did not fix the problem pass it to service center.
Oct 20, 2007 | Epson 5300 7200 7300 Replacement Lamp -...
Epson (1023661) Projector Lamp for PowerLite ELP-3000, 330 Logo
187 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
