Question about LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
TruMotion Demo. My TV was a Shop Display Model but I would like to know How can I remove the TruMotion Demo Disply which keeps coming up on screen. Regards. Harry
  • 362 Answers
Hi Harry,
From the Picture Menu, the option at the bottom is Trumotion demo. Highlight this and press enter, turn demo off, press return.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 29, 2009
  • Jason Morris Jan 29, 2009
    Here is the link for the manual
    http://us.lgservice.com/index_b2c.jsp
    Toward the bottom of the page click on your model# and download the english pdf version.
  • korno_666 May 04, 2011
    nnooo men just change your settings go to "options" go down and turn " in store " to "home"
2 Suggested Answers
SOURCE: TruMotion Demo
If anyone else has the same problem it can be sorted by going into the main menu - select display - select advanced at the bottom of this screen - in this menu you can turn on/off the trumotion demo.
Posted on Feb 02, 2009
I have a scarlet LG tv and the Trumotion demo keep popping on the screen which is really annoying. I went in the picture option set trumotion off but it still showin it. please help!!
A reset to factory condition will clear it. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 12, 2016 | LG Televison & Video
How do i remove the 4 boxes that keep coming up at the lower left of the screen?
  1. go to main menu -
  2. select display -
  3. select advanced at the bottom of this screen -
  4. in this menu you can turn on/off the trumotion demo.
May 22, 2016 | LG 42LG50 42 in. LCD HDTV
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
Demo mode keeps on popping up on sony bravia. how do i permanently remove it
hi,
you can exit the DEMO MODE by the following setup.
Power ON the television
1. select "TV" mode (not AV, demo mode can't switch off when ur in AV)
2. Press the "home" button on the remote.
3. select "settings".
4. select "set up" .
5. Scroll down to "factory setting" and restore them.
6. when it asks home or shop display select "home".
ok
Jan 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do i permanently keep demo mode off on my JVC car cd player? Everytime I remove the fascia it resets the settings and the demo mode comes back on. The model I have is the KD-R711. Thanks
Hold down the menu button for about 2 seconds.
Will take you to menu mode, first option should be demo, if not scroll over to demo menu
by using the know. Push the knob in to enter the mode, then using the knob get to off display, push the know in once again to set it to off. After hit the menu button to get out of menu mode.
Jan 08, 2011 | JVC AM FM CD DET FACE CAR STEREO
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
TruMotion Demo
Jan 29, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
TruMotion
dont put the LCD neaer magnetic things like speaker or ampilifier......when the problems happend?
Aug 18, 2008 | LG Flatron L1715S 17" LCD Monitor
Demo Mode wont go away!!
to turn off the demo mode on model 32af42 toshiba tv you can either press recall,exit or power buttons / if this fails enter the menu screen go to the setup menu highlight demo select stop .
Sep 15, 2007 | Toshiba 32AF42 32" TV
LG Scarlet 42LG6000 42 in. HD-Ready LCD TV Logo
1,327 people viewed this question
Computer Repairing
Computer Repairing
