Question about Bose Companion 3 Computer Speakers
Control Pod for Bose Companion 5 speaker system
I just bought the Bose Companion 5's about three days ago. The volume for the control pod didn't work from the moment I got them connected. The headphone jack and everything else works fine, it's just the volume wheel. I have to control it by the main volume on the computer. Do I have it hooked up wrong or is it just the control pod. The thing is brand new for crying out loud. Thanks for the help. Kelsey
  • 5 more comments
  • Richard Hamm Mar 01, 2009
    I have exactly the same problem.
    Have you found the cause yet? I'm still looking for a sollution.
  • Anonymous Mar 10, 2009
    I have the same problem my pod got crushed.
  • Anonymous Mar 23, 2009
    The control pod do not work, I can not control volume and use the touching function.
  • Anonymous Apr 15, 2009
    Just connected the Companion 5 and the volume wheel won't work just volume from my mac and pc any solutions
  • daverw21
    daverw21 Oct 26, 2012
    I've had a Bose Companion 5 Computer speaker System (purchased in the UK) for just over 2 years. Admittedly, I now live in a hot country (Malaysia), but the black volume ring on the control pod has now started to go really sticky. The plastic seems to be in meltdown mode. You'd expect Bose to have tested their equipment in all climates.
  • Wesley Jul 19, 2013
    Awesome fix dude!
  • Jeff Murkot
    Jeff Murkot Mar 09, 2019
    This worked for me Thank you so much! LOL I was pricing new ones on Ebay and they are well over 100$ You saved me good money
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Posted on Jan 26, 2010
  • 12 more comments
  • Sarnster Dec 24, 2010
    Thanks for posting this, you made Christmas day much more enjoyable
  • mjoinhk Jun 11, 2011
    Thank you - works perfect now !
  • sawds
    sawds Jul 23, 2012
    Thanks so much for posting... Saved so much frustration.
  • mhfisk
    mhfisk Aug 19, 2012
    Same problem... and an effective solution on my Mac-mini, THANKS MUCH!
  • totodrum78
    totodrum78 Dec 03, 2012
    Thank You so much!!! It worked!!!
  • mvheeringen
    mvheeringen Mar 25, 2013
    I did it exactly as you said: unplug power, unplug pod, connect pod, connect power and it worked!! Thanks!
  • C S Nunemaker May 25, 2013
    I did the same on my 2013 iMac. Worked like a charm. Hurrah!
    Perfect fix!
  • Ruel Lazaro
    Ruel Lazaro Mar 24, 2014
    worked like a charm!.. :)
  • Ruel Lazaro
  • Brady Liu
    Brady Liu Oct 22, 2017
    Perfect solution. Thanks :)
  • Damien Kwok
    Damien Kwok Oct 24, 2017
    Good solution. Thank you
  • Ryan Rajkumar
    Ryan Rajkumar Jul 26, 2018
    Thank you so much for this info - I returned one I bought thinking it was defective to Bestbuy even had a Bestbuy tech used remote access and could not diagnose the problem......was told to contact Bose they advised I returned it to Bestbuy......got another Companion 5 same problem......then followed your instructions and it worked......thanks so much,
  • Jeff Murkot
    This worked for me. Thank you so much. I was pricing new control pods on ebay and well over 100$ You saved me money. Thanks!
Same thing happened with me on my Mac Book pro and then on my Dell Desktop.
Then I realised something.... I had plugged the USB in whilst the light on the control pad was RED in muted mode. So firstly I unplugged the USB from the PC, waited a little while, pressed the control pad to be lit GREEN, then plugged it back in. Hey presto worked fine.
You could also try removing the Human Interface Device driver from the Device Manger listing, open a few up and look for the one which says Location 0 (Bose USB Audio) and in driver select 'Uninstall'
Hope that works for you, it had my about to pack it up and ship it back!!!! Bets of luck O:)
Posted on Apr 15, 2009
SOURCE:
Where i can buy the volume control of the companion 5
  1. How To: Fix your Bose Companion 3 [Warning: I'm very ...
    ? 3:18
    www.youtube.com/watch?v=gXRJ5Zgq84UNov 15, 2014 - Uploaded by Guizmaille (You can tell it's the control pod and not the sound system itself.... I tried different combination) until I have a decent sound, with both speakers and subwoofer working. ... I think that you can manage to keep the volume control.
Jul 21, 2015 | Bose Audio Players & Recorders
Need new control pod for companion 5
Can you explain the problems you are having for dropping it many times? Is it just physically damaged from outside / The cuircit inside is broken / Completely dead? Would be easier for me to solve the problem. Few days ago I bought a new Control pad from ebay which was $85. See, if the circuit is broken inside or the cable is damaged surely we can come with a solution.. I have a working control pad Cuircit and other spare parts.. so if u can find out the part needs to be replaced then i am sure u can cut down this expense. Thanks.
Nov 23, 2013 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Control pod on bose companion 3
try to check the circuit board with an expert
Nov 16, 2008 | Bose Companion 3 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
26,661 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
