Asrock P4i65GV Motherboard
Problem for Asrock P4i65GV Motherboard
Not booting but RAM,processor,SMPS ,HD are fine.
By praveenkashi on Jan 29, 2009
no power beep. Cpu fan,processsorr fan every thing is fine....
Comments:
Jan 29, 2009
- power supply to motherboard is working fine as processer fan is running,cpu fan running,dvd rom light also glowing.
I hv checked RAM,SMPS with other systmes its working fine.
Problem is with motherboard only. But the thing is i m unable to know the exact problem,pls help.
Jan 30, 2009
- DVD light not constantly on.Its working as normal.
Above Motherboard problem occured when sudden power OFF happened (My PC was not connected to UPS) .
Clarification Request
Posted by dutchdj on Jan 30, 2009
Whats the brand and model PSU you use??
Posted by dutchdj on Jan 29, 2009
is your dvd light constantly on? if yes check if IDE cable is in properly and reverse if needed..
Posted by Celenous on Jan 29, 2009
Please list the specifications for your components. Also, how do you know the components are working correctly?
Same Problem
Feb 23, 2009
-   Each component - power supply, hdd, cpu...- is fine, when I check with other computer. But this mother board doesn't get any power at all.
How can I check the motherboard is completely dead?
-   Say Lee
Solution #1
posted on Aug 24, 2009
Not Rated)
satish_pb
Rank: Apprentice
Rating: 0%, 0 votes
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Was this helpful?
Yes
No
Popular Solutions for Asrock P4i65GV Motherboard
Questions and Unsolved Problems for Asrock P4i65GV Motherboard
Do you recommend Asrock P4i65GV Motherboard?
Answer
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
i have a desktop dv9000, that have stopped connecting the monitor, i tried the monitor on my other... (More)
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
how do i unlock channels on an ntl set top box?
Answer
set up my routter and still having a low id where it doesn't even get close to the speed it used to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
