Question about Compaq Armada 1700 Notebook
Hard drive controller problem
Model Armada 1700 6266/4000/D/M/1 I am getting a hard drive controller error when running diagnostics. I get a" smart hard drive detects imminent hard drive failure " message when I boot up. I press F1 to ignore & it boots up fine. Then depending on the size of programs I run it will blue screen with a error & begin a memory dump. Sometimes it will run fine until I close it out. Other times it will not even complete loading the operating system. I am running Microsoft 2000 Pro. Is the controller replaceable? Do I need a new motherboard? Is there anything else I should look for etc. Any help is appreciated.
    President:
  • 2,961 Answers
S.M.A.R.T (system monitoring)is the warning software that detects when a hard drive is about to fail, so i would back up any important docs to a disc or usb drive immediately and replace the hard drive. The hard drive controller itself will not be the problem, it's the controller saying that the problem is the drive, the controller is only a driver and not a peice of hardware, pressing F1 will ignore any faults and continue to boot, but especially if it doesnt always boot it's definately your hard drive.
Posted on Jul 26, 2007
SOURCE:
How to manage BIOHD-8 Error Code
Hi
If your drive is showing a SMART error I would consider replacing the drive as its showing the 1st signs of failing and if you don't have backups of any important data on there I would back it up now as when it failes you wont have any way of recovering your data
Cliff
Aug 21, 2014 | HP Computers & Internet
Raw Read Error Rate problem! How can I get it fixed?
The Smart features on hard drives are for hardware diagnostic purposes. This is a sign that your drive may be failing. I would backup any files just in case. Then consider replacing the drive.
Nov 13, 2013 | Seagate Computers & Internet
Error message : Port-00: Hard disk, ST3250312AS smart command failed
The hard drive failed diagnostics. Either your hard drive is bad or the hard drive controller.
Jul 06, 2012 | Dell Computers & Internet
Compaq armada 1700-when powering the system the following error appears "Error loading operating ststem"
There is a good possibility that the hard disk drive may be failing, so if you can try running diagnostics and see if you get a failure on the hard drive.
If you can't run diagnostics, then boot to your Windows CD, press R for recovery console, then at the command prompt run the command CHKDSK /R see if you get any errors on files.
If that doesn't resolve, then boot to the windows CD press enter instead of R and repair windows.
If that still fails, then the hard drive is likely bad
Aug 20, 2011 | Compaq Armada 1700 Notebook
I have a problem with my dell studio laptop stating like smart hard disk failure in statrup and asks to hit F1 to continue..please give a solution for this problem...
Normally the SMART error occurs when the hard drive has gone bad.. What you do is.. Try running the dell diagnostics by turning on the computer holding the FN key.. It will run some tests... If it provides any error code then the Hard drive has gone bad you need to replace it.. Call up the Dell or a local tech and replace the hard drive
Oct 06, 2010 | Dell Studio 15 Laptop
I get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Dec 11, 2009 | Dell Computers & Internet
Error reading hard drive laptop Armada M700
It's sadly possible your hard drive is bad or corrupted. Can you boot from a CD? Or a floppy disk? You could run diagnostics on it from a CD. If you don't have one available check the HP website for support.
Sep 24, 2008 | Compaq Armada M700 Notebook
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Hard drive controller again
I don't think you have a hard drive controller fault as such... more like your hard drive is going "Flakey" meaning it is developing "Bad Sectors" IE the magnetic media going bad, this is common occurance.. I think you had better backup any valuable data and get a new hard drive and transfer your "Old" drives contents to your "New" drive. There are many programs that can do this for you.. Just Google it. One could install the New hard drive as a new "Master" and set the old as "slave" install a new operating system on the "new" one and then transfer the data from the "old" drive to the "New" and then ditch the "old" ya be good to go.
Jul 30, 2007 | Compaq Armada 1700 Notebook
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Compaq Armada 1700 Notebook Logo
167 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
