Question about HP 510 Notebook
Keyboard hassles My HP 510 Laptop keyboard returns(certain) "wrong" characters when I type. " = @ for example. how do I change settings to correct this? Thanks Danny
  • Anonymous Mar 02, 2009
    kl i o p m 0
    this key is not working anther all key is working
    this key prass than come to anther word coming
  • bird3696 Mar 25, 2009
    exactly as desribed if you want type @ you have to type "t
If everything in control panel-regional setting and language OK, try to press together FN+NUM LOCK (FN-after ctrl on your left side).
Posted on Apr 06, 2009
  • 95 Answers
You can go to control panel and check the language selected under regional and language options. Check under the Regional optional and language - details tab, the language selected should be English (US). Let me know if this works.
Posted on Jan 29, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Brother CM1000 is not working when typing a caracters return wrong one for example when "a" return "fr"?
    for em-530
    "Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off for 10 seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center.
    Dec 04, 2013 | Brother EM-530 Typewriter
    When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
    Hi
    Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
    Or try this
    If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
    Try the following steps in case your laptop keyboard displays wrong characters:
    1.Go to the control panel option
    Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
    2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
    3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
    4.Click ?
    'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
    This should solve your problem
    Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
    Toshiba laptop keyboard doesnt respond to certain keys with correct letter. for example typing U gets a 3e?????
    Hi
    Go to the control panel and select the regional and language setting, Tab select Language and click the detail, you get new screen Text Service and Input Language hear you can select the Keyboard language (Default English United State) and change the keyboard setting. now your get perfect key before your have,
    Good Luck
    May 26, 2011 | Toshiba 310CDT Keyboard
    I sometimes accidentally switch the keyboard to characters other than standard English. I don't even know how I do this. How do I switch back to the standard keyboard? If I switch the computer off, then...
    There should be a sequence that you need to press to change it from one type of keyboard characters to another. Look for a key that has the symbol of a keyboard on it. Most likely this is the key that is causing you the problems. Typically you have to press the Function key that is near the space bar as well as the key with the symbol on it to change it from one character set to the other. Evey laptop keyboard is alittle different than the next when it comes to which keys are "functions keys", so you will have to examine your keyboard to find the correct key on you laptop.
    Aug 05, 2010 | HP Compaq Presario CQ50-110US Laptop
    I own an HP 510 laptop, when i type the function symbol on the right side of the keyboard is displayed for eg if I want an L 3 is typed, O is 6 etc. To eliminate this I must press the FN key to get the...
    You have the Num Lock on.
    To turn it off just hit the Num Lock key or press Fn and hit the Num Lock key to return the keyboard to normal.
    Regards.
    Jun 28, 2010 | HP 510 Notebook
    My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
    Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
    Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
    The keyboard characters does not correspond to what appears on sc
    Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
    Feb 27, 2009 | Dell Inspiron 500m Notebook
    Keyboard changing key configuration
    the key combination you mention is Left Alt + Left Shift.
    It changes the keyboard layout to the next one in the listed of available keyboard layouts.
    To configure the layouts, go to Control Panel -> Regional and language settings -> Languages tab -> Details
    Under Installed services, the keyboard layouts that are currently installed are listed.
    If you don't need to change (is needed if you want to type norwegian for example, since it has some special characters), you can simply remove all unnecessary layouts.
    May 23, 2008 | Logitech Cordless Desktop S 510...
    Non-English keyboard characters ??""""?..?.????????
    it is in a particular file or everywhere you are typing? if everywhere u are tping then press (function key ) fn+Numlock key for laptop. it will be correct if it is in a particular file then check the file format and another editor for opening the file.
    Sep 13, 2017 | Compaq Keyboard
    HP 510 Notebook Logo
    423 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
