May problem is "inputting four numbers and get the minimum number of them, and would be outputting the number in ascending order, BUT skipped the number end in zero and zero number..in javax swing"please help me.. thanks
  • Celenous May 11, 2010
    can you post a sample of the code you are working with? You can do alot with swing and would need more info before this can be answered
    Brigadier General:
  • 10,406 Answers
/* REXX is a better programming language than Java with Swing */
data = '11 10 0 3 12'
filtered = ''
do while (data > ' ')
parse var data value data
if left(reverse(value),1) = '0' | (value % 10 = value / 10) then iterate
if value = 0 then do; say 'Excluding:' value; iterate; end
filtered = filtered value
end
say 'After filtering, numbers are:' filtered
keep = filtered
parse var filtered smallest filtered
do while (filtered > ' ')
parse var filtered value filtered
if value < smallest then smallest = value
end
say 'Smallest value is:' smallest
n = words(keep)
do j = 1 to n
sorted.j = word(keep,j)
end
say 'Smallest to largest:'
do j = 1 to n
do k = (j+1) to n
if sorted.j <= sorted.k then iterate
t = sorted.j
sorted.j = sorted.k
sorted.k = j
end
say j sorted.j
end
say 'Done:'
exit
Access http://www.REXXLA.org to download REXX for your PC (Windows or Linux).
Posted on Nov 20, 2009
What is medium of 2,4,6,6,7,8,10,11,13
https://www.easycalculation.com/statistics/mean-median-mode.php
The mean (average) is the sum divided by the number of items regardless of individual values. Here is is 7.4444, rounded off.
The median is the middle number in the group, listing in ascending order. You have 9 items. The fifth one as four above it and four below it. It is a 7. (A selected group of numbers is referred to as a data set. If taken from a larger group, the selection is referred to as a subset.)
The mode is the most frequently listed number. Only the 6 repeats itself in this example. That makes it the most frequently repeated number.
Understanding How to Calculate the Mean Median and Mode
Sep 17, 2017 | Computers & Internet
What are the tune r numbers
For 6 STRING GUITARS, tune strings in
ASCENDING ORDER: Target Hz
For 6 string guitars. Tune in ascending order
First LOW E . . . . . . . . . . . . . . . . . 82.4
Second A . . . . . . . . . . . . . . . . . 110.0
Third D. . . . . . . . . . . . . . . . . . . 146.8
Fourth G. . . . . . . . . . . . . . . . . . 196.0
Fifth B . . . . . . . . . . . . . . . . . . . 246.9
Sixth HIGH E. . . . . . . . . . . . . . . 329.6
For 4-5 string BASS GUITARS, tune strings in
DESCENDING ORDER: Target Hz
For 4 and 5 string Bass Guitars
First G . . . . . . . . . . . . . . . . . . . . . 98.0
Second D. . . . . . . . . . . . . . . . . . . 73.4
Third A. . . . . . . . . . . . . . . . . . . . . 55.0
Fourth E. . . . . . . . . . . . . . . . . . . . 41.2
Fifth B (if 5 string) . . . . . . . . . . . 30.95
The manuals are here.
http://www.snarktuners.com/contact-service
Jan 16, 2016 | Snark Clip-On Guitar & Bass Tuner
How do i convert my numbers in ascending order?
How do you sort the data in ascending order? I scanned the guidebook several times and could not find any reference to sorting the data in any order. It looks like you have to enter the data in lists, already sorted by you. Sorry
Jun 28, 2012 | Texas Instruments TI-36X Pro Scientific...
12345 security code is not except in nokia model 1650
*#7328748263373738# to reset security code to default.
Default security code is 12345
i hope this helpful
thank you for using fixya
Mar 07, 2011 | Nokia 1650 Cell Phone
I hook up my speakers but have very little sound why
First of all take an AA 1.5 cell and use it to test the speakers you are using. If there is good movement of the coils identical to both sides , we can proceed further. Now open the power amplifier and check within the output side where all the mosfets are mounted. Check for the +B( the main Voltage) in both the L&R sections of the amplifier. Now use a good signal tester or even you can use a line output audio with a serious capacitor ( about 2.2 mf) to check stages in ascending order from the output stages. Test at all the couplings to confirm the gain of the amplifier. The fault could be failure in the preamplifier or the source selector. Try to check all the inputs , if there is better output in any other source input, in such a case use this till you can get help to change the preamp selector. hope this helps. Good day
Jul 18, 2010 | Kenwood Audio Players & Recorders
Need help connecting my eq to my system.
You will want to connect all of your devices to the pre-amp or receiver, then connect the outputs of your pre-amp/receiver to the inputs of the EQ. Then connect the outputs of the EQ to the inputs on the amplifier or receiver. If you give me some model numbers, I would be able to tell you exactly which cables go where.
Mar 31, 2009 | Audio Players & Recorders
Aks the user to input words and arrange them in ascending order
I HAVE SONY VAIO VGN-CR354
OPERATING SYS. IS VISTA
MY PROBLEM IS THAT THE SOUND THAT COMES FROM THE SPAEAKERS IS VERY LOW EVEN WHEN I INCREAS THE VOLUME.
Mar 27, 2009 | Apple Computers & Internet
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
