I had a transcend 8GB JFV10 flask drive and it show "remove write protection from the volume transcend in drive\device\harddisk2\DR7
  • jcagulada Jan 30, 2009
    there is no available button on said thumb drive. Anyway, thanks a lot, I solve it by myself
    Problem Solver:
  • 16 Answers
The WRITE PROTECTION is ON. Please push the little white button on the side to the other end. Then try access it on your computer. If it still gives the same error, push the button to the other end and try again.
Posted on Jan 29, 2009
Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
First
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
However if that does not solve your problem try this
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
Jun 24, 2011 | Transcend (589307) Media
When i format transcend 8gb jf v10 it says disk is write protected. I'm not able to add data or format it please help..
I have purchased 8gb Transcend Pen Drive When i Connected the drive in computer a message shows "Please insrt a disk into drive". I have checked in several computers but the problem is same. Although the disk is detected but not shows the capacity when trying to open this message displayed. I have change the drive letter from my computer "Manage" option but the problem is same. What can i do?
May 14, 2010 | Computers & Internet
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
May 31, 2009 | Transcend (589307) Media
Format 4gb transcend flashdrive JFV10. " WRITE PROTECTED"
plug in pendrive right click on it
click on properties
go to tools
and click on backup now
Apr 12, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
USB 16 GB transcend says disc is write protected!!
You should try to delete the partition in the Transcend memory stick and creat a new partition. You should copy any files that you need off this memory device before you re-partition it because you will lose all the data that is stored on the device.
Go to the Control Panel - Administrative Tools - Computer Management - Disk Magament.
Scroll down until you see your removeable device the 16Gb memory device, click once on this, It may not show it as Healthy.
Right click in this disk (make sure you do not select the C drive) and click on Delete Partition to remove the partition.
Right click on this unpartition drive and Create a partition.
You may not have to format this partition, it should now show this as a healthy drive.
Exit out of Disk/computer Management and Control Panel.
The USB drive should now function normally.
Mar 04, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
