Question about Dell E151FP 15" Flat Panel LCD Monitor
Power Led (Green) Flashing
Hi for everyone... For some reason, my monitor went to black screen and the power led started flashing on green. I try to look for an error code on internet and I did not find anything about it. When I pressed the power bottom, it continued flashing, and it never shut off. Any hints will be appreciated, Thanks Antonio
  • 2 more comments
  • Antonio Ducreux Jul 28, 2007
    Hi Talk2dfre:
    Thanks for your reply. I am currently using the CPU with a CRT monitor. The CPU and Video card is working fine.
    Antonio
  • Brouwer41 Nov 06, 2007
    I had the same problem last week. The monitor power button was flashing green. the screen was black and periodically flashing. I unplugged the power cord and the computer cord. After plugging in the power cord without the monitor connected to the computer, the monitor started in the test mode (test pattern on the screen). I turned off the computer and monitor and reconnected the monitor to the computer. I restarted the computer and the monitor was fine for several days. I now have the same problem with the monitor flashing green. I tried to reset as I did last week and I was not able to restore the monitor.
  • babeliii Dec 29, 2007
    hi,
    i'm also facing the same problem. the screen will shut off by itself after some time, and also i can smell a slight burning smell. To get the display back, i will need to off and on the monitor, but it will only display for a short while only.
    i have used the methods as described but it is still the same.
    thks in advance!
  • lhj90 Mar 10, 2008
    I experience the same problem as well. i would really appreciate it if somebody can provide me with a solutions?
I believe the computer is causing the monitor to lock up. To reset the monitor, try unplugging the monitor from the computer in addition to the power cord. Connect the monitor to the video output of a seperate computer (I connected mine to a laptap). Start up the computer and plug in the power cord. This reset my monitor and I was able to get it to work for now.
Posted on Nov 07, 2007
    Problem Solver:
  • 15 Answers
Inorder to verify that the problem is with the monitor have you tried the monitor with another CPU could you please try it because it might be a problem with it the signal may not be reaching with monitor
Posted on Jul 26, 2007
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Does anyone have a schematic for a Samsung 35135A power board in a Dell E173FPs flat screen monitor?
You can probably get one from eBay or try Dell's website. You can download user manuals and tech manuals. at dell.com
Apr 09, 2012 | Computers & Internet
Dell 173FP - black screen - green flashing power LED
It can be bad fuse, shorted trnaistors inthe inverter circuits, bad caps, transformer. See the pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Post back what you find so we can guide you further.
Mar 10, 2010 | Computers & Internet
Black screen flashing power led
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
May 08, 2009 | Computers & Internet
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Dell E151FP 15" Flat Panel LCD Monitor Logo
251 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
