Question about Microsoft Windows XP Home Edition
How to install vista - Microsoft Windows XP Home Edition
  • Microsoft Master
  • 19,396 Answers
    President:
  • 949 Answers
I did not think I seen this, but the install info is for a brand new HDD, if reinstalling vista you should
pick advanced at the bottom, delete the drive, then format the drive. It is really better if you had a disk called Ultimate boot disk, which there are hard drive eraser tools on it, unless new HDD you want to wipe it when reinstalling, vista format is a very poor format for drive.
Also if you do not know how to enter the bios so the first boot is a cd or dvd drive, when you first start
pc you should see an option for enter bios or boot option, pick boot option and pick the hard drive,
this will force boot the drive to give you the boot from cd option.
Posted on Mar 21, 2009
  • odiebugs
    odiebugs Mar 21, 2009
    Forgot, you should never try to get out cheaper and get an upgrade
    to an OS, if you do, and something happens to the boot,and you want to reinstall the OS, you need to install both again. Thanks to microsoft, but bill gates does not have enough money so we feel sorry for him.
How to install windows vista
Posted on Feb 26, 2009
    President:
  • 2,559 Answers
Before you get started loadTOCNode(2, 'summary'); Before you begin to install Windows Vista, make sure that you have everything that you need for the installation. Make sure that your computer meets the minimum system requirements to install and run Windows Vista. Also, determine whether you must perform an upgrade or a clean installation of Windows Vista. Use the information in this section to help you make these determinations. Internet Connection loadTOCNode(3, 'summary'); Make sure that you can connect to the Internet. System requirements loadTOCNode(3, 'summary'); The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK)
loadTOCNode(3, 'summary'); loadTOCNode(2, 'summary'); To upgrade the current Windows operating system on your computer to Windows Vista, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, go to the "Next Steps". Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully. Please rate this fixya
Posted on Jan 29, 2009
I have a Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me...
If it does not install in vista(if you want vista appearance and also to install the software).the possible way to install is:
1.format the pc and install windows xp.now you will ask that i want a vista appearance why should i format and install xp,so i have also have a solution to it.follow it on second point.
2.now install vista inspirat 2 which will give you a vista appearance same like vista.
3.install the software you want ,now it will support your pc,because it is xp and the most important factor is that you have a vista appearance.
if you need help call me on:9920207375
Sep 20, 2009 | Microsoft Windows Vista Ultimate Edition
Vista
yes you can install vista....................without lossing your data.......
If you are running windows xp then don't install the vista where you have installed xp...........just installed the window vista in other drive
If your system is running in vista only.......then u can install the vista on that drive this will not lose your data
Aug 24, 2009 | Microsoft Windows? Vista Home Premium...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Installing vista themes
The following link provides a detailed description of how to install vista themes on your pc:
http://www.themebin.com/customizations/install-vista-themes-visual-styles/
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
Intex tv tuner
Most program that are designed in XP doesnot work sometimes with Vista because of new features and new version of DirectX.
If you are installing the driver in Vista and is made for XP, and installation failed then wait for sometimes because Vista Recalculates the version and try to install the driver from recommended setiings. You wil get the option to choose to install this software using recommended settings. If it doesnot install and installation failed then try searching it's driver for Vista from internet.
Most probably recommended installation solves the problem of incompatibility of driver with Vista.
gimme your Acknowledge by rating me
thanx
Romy
Aug 01, 2008 | Microsoft Windows Vista Ultimate Edition
Cant re-install windows vista to my dell vostro 1700
Did you try the repair option again, this time just choose repair. If not you need to clean install the computer. You can go the microsoft site to get full instructions for "Clean Install Vista"
Dec 09, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Home Edition Logo
356 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
