Does DVI conecetion transfer the same picture quality as HDMI?
Does it?
I think it has the same quality
but it wont transfer sound like hdmi does
Posted on Jan 29, 2009
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
I just purchased an ACER P236H-BD monitor described as full HD 1080 but does not have an HDMI input. Does a DVI input give full HD 1080?
Yes dvi can output 1080p video. There is no signal conversation when using hdmi and dvi. Vga however has lower picture quality because signal conversation do exist.
Mar 20, 2011 | Computers & Internet
My tv does not have an hdmi port. I have a device I'd like to import (Apple TV) I'd like to connect. It has an hdmi input for connection to the TV. Is there something I can do to be able to connect to a...
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
Jan 14, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
Where does the HDMI cable plug into for a Blue ray player?
i have the same tv. there is only a dvi input with separate audio inputs.you will need a dvi to hdmi adaptor to connect for hi def.hdmi is video and audio while dvi is only video.you still get the picture quality,but have to run audio rca cables also.
Jan 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 60
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Dec 14, 2008 | Philips 60PW9363 60" Rear Projection...
Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Oct 25, 2008 | HP Compaq WF1907 Monitor
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
HDMI Cable?
Hi CrysR,
Although you may not be able to locate a cable with one HDMI male end and one USB male end, it is possible you may find a solution with an adapter.
I recommend looking for an adapter that will accept USB input and output to either HDMI or DVI. If you only locate DVI, you can then add a DVI to HDMI adapter at the end.
Be aware with these extra pieces and signal transfers included, it may degrade the quality of your picture.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
