Drum is filling with water after each wash
I do hope you can help :)
We have an Electrolux washer-dryer EWD 12141 and the drum is slowly filling with water (approx 2'') after each wash (the drum is clear of water when wash cycle has finished). We use the RINSE HOLD program before each wash simply to get rid of any collected water in the drum. May the problem have something to do with hard water?
Many thanks in advance.
Joanne
  • Washing Mach... Master
  • 3,463 Answers
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Posted on Jan 29, 2009
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
My ewd 12141 trips the electric
If this machine is new, the circuit may have inadequate amps.
If the machine has been in place for a while, and this is a new problem, you may need an electrician to test the circuit breaker. They do wear out and need replacement.
Oct 12, 2014 | Electrolux Washing Machines
Programme dial on Electrolux ewd 12141 has worn off and the manual does not have a picture. Can anyone help me??
check on e bay or contact manufacturer for replacement. failing that try searching online for an image of said dial and mark on setting you use with a permanent marker pen
Mar 08, 2012 | Washing Machines
After doing wash ...while empty and off...the washer slowly fills up with water overnight...approx 3" deep of water in drum...slow leak valve maybe?
Yep!
If your washer is both hot and cold fill turn one of them off overnight. You will then tell which water inlet control valve is not closing correctly and therefore which one needs replacing ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 22, 2011 | Electrolux EW1000i Front Load Washer
The washer fills slowly with water when not in use. It drains without any problem when drain/spin cycle is used.
Most likely the water inlet valves on your washing machine have failed. You may have noticed larger amounts of water in the clothes drum when the washing machine hasn't been used for a few days, this is because the valves may still be open allowing water to drip into the clothes drum.
Here is a link to the part that you need to buy: http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Washer-water-inlet-valve--universal-item-number-AP3098982.aspx.
And a link to a video showing you how to replace the part: http://www.ultimatehandyman.org/video/appliance_repair/water-inlet-valve.php
Hope this helps!
Feb 28, 2011 | Whirlpool GHW9400 Duet Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Fills with water slowly when not in use
You have a faulty solenoid valve..
At the back Where the water inlet pipe connects to the machine, the valve it connects too is faulty order a new one and replace it yourself... al you have to do is remove the top to get to it.. and its straight forward ......
Hope this helps any questions dont hesitate to ask ....
Jan 22, 2008 | Electrolux EW1200i Front Load Washer /...
Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
