Question about iLO DVD Recorder DVDR05
Dvd recording I made a disc using Maxell DVD-R on my Ilo recorder. I an play this disc on the ilo but cannot play it on my other dvd player. Can you tell me why?
  • Anonymous Feb 07, 2008
    i have a DVD R 05 i was always taping from my tv and i have always used
    Sony disc DVD+R 4.7 GB well lately i can't seem to play what i tape on
    other DVD's players when i play it on others it freezes on me, then it skips
    scenes, stops then it starts again, but when i play it on my Ilo recorder it
    plays perfectly fine.What happened here
Could it be the write speed of the disc, try a slower rewriteable and see if it improves any???
Posted on May 20, 2008
  • 32 Answers
A lot of people put too much in cd\dvd disk. In order to 'close' you must give at least 1.44meg [simulor to 3 1/2' floppy space] I read someware up to 3 megbytes! As suggested by Mr. Guest
Posted on Sep 26, 2007
Have you close the disc
Posted on Jul 26, 2007
SOURCE:
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
I have an ilo dvd ro4 and when I put a disc in it says invalid disc
Laser is either dirty or starting to wear out.It may also not be a compatible disc,not all brands of discs work in this model.The unit records on R+Rw+ discs 4x speed or slower.Variable speed discs1x-16x will also work.
Most of the time it is just a dirty laser that can read the disc,to clean laser use a commercial laser cleaning disc,Phillips and Maxell work well in this model.Put a drop of rubbing alcohol on cleaning brushes.
Jul 06, 2009 | iLO DVDR05 DVD Recorder
Ilo=R/RWDVD RECORDER,DVDRO4,CANNOT GET YOUR COMPANY TO ANSWER HEL
This unit only uses DVD +R or +RW. I have found the Maxell works the best with mine.
Mar 17, 2009 | iLO DVD Recorder DVDR05
Ilo dvd recorder do not recognize any dvd
According to www.dvdrhelp.com that this unit is very picky on what discs it will record on. Look up unit and read the large number of reviews in DVD Recorder section
Dec 25, 2008 | iLO DVDR05 DVD Recorder
My ilo recorder wont take any disc
If it won't play any disc including prerecorded movies, then try cleaning the lens.
Nov 02, 2008 | iLO DVDR05 DVD Recorder
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
ILO Recorder DVD05R - Playback jumps 10min, 20 min and more...
Does the disc still play in other dvd player? My ILO has always been picky to play rentals so I just have a cheap COBY player hooked up to front inputs of my ILO. I use it to watch the dvds, only use the Ilo to record. Saves wear and tear on my ILO but cannot find a universal remote to operate them both and my tv. If it still records okay thats what I would do, just watch the discs in a secondary unit. Sounds like time to start shopping for new recorder.
May 04, 2008 | iLO DVDR05 DVD Recorder
ILO DVDR05 recorded DVD's freeze
Burn your DVDs at tow positions slower than what the system and discs say. It sounds as if there is a huge amount of error being introduced during the write process. Unfortunately, the old discs can only be recovered with an external program like Zero Assumption Recovery or the like....accordianman
Feb 28, 2008 | iLO DVDR05 DVD Recorder
I purchased the DVDRo4 and its been pretty reliable so far.
These R04 are fickle,some Brands of DVD discs won't work in ILO,try another brand.Also clean laser in iLO it may be dirty,use commercial cleaning disc,put a drop of rubbing alcohol on brushes.Do not use any other chemical.
It is possible you laser is defective or starting to go.If that's the case you need to replace burner/loader.
Some dvd recorders formulate a little differently,I have made recordings in my iLo that won't work in all brands of players/recorders.
Aug 14, 2007 | iLO DVDR04
NONFINALIZED DVD'S THAT ONCE PLAYED WILL NO LONGER PLAY
This seems to happen with alot of dvd recorders especially if discs left unfinalised for long periods of time.This happens on all makes of recorders not just your model.Also the quality of the dvds being used can be the problem.How old is your recorder as the only other problem which could cause this is the laser losing power
May 09, 2007 | iLO DVDRH04 DVD Recorder
iLO DVD Recorder DVDR05 Logo
76 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
