Question about Panasonic EUR7724020 Remote Control
My remote EUR7724020 is broken. I want to try and fix it..i have open the remote but I don't know what is wrong with it.
  • 55 Answers
If you are using a Panasonic remote to control your Panasonic TV, press the TV button followed by POWER and you should be all set
Jan 28, 2013 | Panasonic EUR7724020 Remote Control
Remote for appollo 1996 fell apart need to know how to reassemble
Replace it, they don't provide repair instructions for this type of device.
Nov 05, 2012 | Cars & Trucks
2004 honda accord driver side lock won't open remote
driver side has most use and breaks down quickest.
Typically, the lock wears, and should be oiled using graphite powder, not oil, as with most outdoor locks.
However, in winter moisture turns to ice and freezes lock.
In this case, try to squirt lock de-icer (usually this is methyl alcohol or some other type).
Don't use an alcohol (such as from drugstore) that also contains water.
that would make matters worse.
If you spray enough lock deicer or even a high-quality penetrating oil, you may be able to work key and lock to a point where you can turn it.
Don't force key rapidly or too strongly, as it will bend, and may break off in lock.
You can spray some alcohol or penetrating fluid on the key to work it into the lock better.
Sometimes, you can get at a frozen lock mechanism by spraying down into **** between window and metal door from above lock.
Sometimes, you might find that the door itself is frozen,
or the lock latch is frozen, and not the key-tumbler.
In this case, you can try body-checking (not kicking) the door,
to loosen the frozen edges around door and window.
If you can get into car from other side, you can sometimes open it from inside to break ice-jam.
If this is an electrical problem
(only remote doesn't work)
The likely cause is broken wire in wire-harness from car body to door.
There will usually be a group of wires either inside a cable or bundled in a rubber tubing, going from car to door at front between hinges.
Here is where the electrical connection will be broken,
because the wires break eventually as they get flexed over and over.
IN this case, the only permanent fix is to find the wire (it will be color-coded), and replace at least 6 inches of that wire (it will probably be broken inside insulating sheath.)
Alternately, there may be an open-circuit at connector to door-latch solonoid. Here you might get lucky if you get inside door-cover off and wiggle or re-insert the plug connector.
Also possible that solenoid is just burnt out or open-circuit.
In that case it must be replaced, for the remote signal to effectively open door lock.
Jan 26, 2012 | 2004 Honda Accord
My driver side door keeps opening even if the door is locked by the key as well as via remote. I even tried manually pushing the lock down and closing the door but it still opens. What could be wrong ?Is...
take your remote and open it up and take the battery out. your remote button is probable stuck on or a piece has broken off inside and is lodge by the open button.
Jul 03, 2011 | 1996 Nissan Maxima
What is the model number for the remote control for the Panasonic PV-DF2035
Try this one:
Jun 16, 2010 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
Hello Myhousekey,
here is a link that should help you out.
If this does then please leave a thumbs up.
Cheers Little Dish Fitter.
Oct 17, 2009 | Panasonic EUR7724020 Remote Control
Sears 1/2 horsepower chain drive garage door opener (circa 1993) would not open with remote and light on back of opener is flashing quickly. Tried reprogramming the remote, but had no success and the green...
It sounds like you have a remote with the button pressed or broken so that it is on all the time. Remove the batteries from your remotes and check that light. The rapid flashing is an indication that it is receiving a signal. Make sure you don't have an old remote in a drawer somewhere.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
2003 Toyota, Remote access not working
Check the antenna and it wiring.
Apr 17, 2017 | 2003 Toyota Corolla
Televison & Video Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
