Question about Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump
Pressure setting of series 90 pumps
Hi, this is chandrakant from india. i am working for Schlumberger asia services ltd. as mechanic. we are user of sauer sundstrand pump . we have a problem with one series 90 pump, we want to set a pressure rating we are getting now 2000 psi and we wnt to increase it up to 3000 psi. is it possible ? pls guide me.
thanks
Well, first you have to remember that your charge pressure is about 10% of the setting pressure, I mean if your main pressure is 2000 psi, then your charge pressure must be set at not lower then 200 psi in idle (650 rpm).
To increase pressure, take a 15/16 wrench and 5/16 allen wrench, on top of pump, at the side of charge filter block, you will see two multifunctional valves, one for port M1 and one for port M2 ( ports "A" and "B")
Remove hoses from such ports underneath the pump and plug them, then with engine in idle, with wrench 15/16 brake lose the top set screw nut of the multifunctional valve, slowly turn set screw with 5/16 allen wrench 1/2 a turn cw, this must increase your pressure about 500 psi, so from 2000 to 2500 psi, do this with both multifunctional valves.
Double check your pressure by stroking manually these pump.
You should increase your charge pressure also, remember 10% of your desired pressure.
main pressure 3000 psi
Charge pressure 300 psi
If you look your pump from behind, at your right hand,little above next to port M2, you will find another set screw with a big nut.
With a 1 1/4 wrench or 1 1//8 wrench, sorry cant remember the right size at this moment, brake lose such nut and turn 1/2 way in set scrwe with wrench 1/2 of an inch. this will increase your charge pressure
Posted on Apr 22, 2009
  • 3 Answers
Yes 90 series pumps will run pretty close to 6000 psi. there are cross port reliefs built into the endcap of the pump and usually a POR valve as well. so the POR should be set at 3000, the cross ports in the pump should be set higher than this. There may also be a "transmission block" which is a seperate block with hot oil shuttle and cross port reliefs. Make sure these reliefs are also set higher than the POR valve in the pump. There may also be cross port reliefs in the motor. These too must be set higher than the POR valve in the pump. If you system overheats after increasing the pressure setting of the POR valve, you are probably loosing oil across one of the cross port relief valves.
Please visit http://hansonhydraulics.blogspot.com for more information. I** If am electric motor is being used to drive this pump, be sure you have sufficient horse power for this increased load. **
Posted on Mar 15, 2009
I want to service my acer laptops 4720z where is the service centre in pune
Benchmark (Acer Authorized Dealer, Acer Showroom & Acer Service Center in Pune) transparent.png Complex , Nr Kesariwada Narayanapeth, 569, Sai kunj Co-op Hsg Soc, Behind Jayanand, Pune, Maharashtra 411030, India+91 98 90 785220
Mar 05, 2011 | Acer Aspire 5610-4648 Notebook
I HAVE A CANON CAMERA OF MODEL NO.- A495....WHICH IS NOT SWITCHING ON AND THE LENS IS NOT GETTING IN.........I WANNA CONTACT INFO OF THE SERVICE CENTRE OF CANON IN JAMSHEDPUR.KINDLY HELP ME OUT............
The closest Canon Service Center to Jamshedpur, India is:
Canon India Pvt Ltd
2nd Floor, Tower A & B
Cyber Greens, DLF Phase III
Gurgaon - 122 002
Haryana, India
Website : http://www.canon.co.in/contactCanonmail.asp
Tel : +91-124-4160000
Fax : +91-124-4160011
They service all Canon products at this location, the rest of the Indian Canon locations do not service digital cameras like your A495.
http://www.canon-asia.com/section/sales_service_contact/?cat=0®ion=36
Cheers, John
Mar 01, 2011 | Cameras
Where is motorola customer service center in mumbai
customer care helpline number of motorola in mumbai
Dec 06, 2010 | Computers & Internet
Where is motorola service center in chandigarh. I need the Battery for Motorola A1200
Here's the address of Motorola service center:
Redington India P Ltd, S.C.O. No.5, Sector 20-D, First Floor, Chandigarh, Near Labour Chowk, Agent - Redington, Punjab, 160 020, India, Tel: 0172-2776131/2776108/2713499, Email: servchdmobile@redington.co.in.
Please rate. Thanks
Jun 22, 2010 | Motorola Mobility MING A1200
I want to use this phone in india purchased in USA, pls advice
Yes you can use that kind of phone in India. All you have to do to make it operable is to buy a sim card that belongs to India country Telecommunications company which offer services to your phone. Below is the list of India Mobile Service Providers.
Cellular Mobile Telephone Service Providers
  • Bharti Cellular Ltd
  • Sterling Cellular Ltd
  • BPL Mobile Communications Ltd
  • Hutchison Max Telecom Ltd
  • Modi Telstra Pvt. Ltd
  • Usha Martin Telekom Ltd
  • RPG Cellular Seravices Ltd
  • Skycell Communications Pvt. Ltd
  • Airtel Digilink India Ltd
  • Fascel Ltd
  • Hexacom India Ltd
  • JT Mobiles Ltd
  • Koshika Telecom Pvt. Ltd
  • Tata Communications Pvt. Ltd
  • Escotel Mobile Comm. Pvt. Ltd
  • Bharti Telenet Ltd
  • RPG Cellcom Ltd
  • Modicom Network Pvt. Ltd
  • Birla AT&T Comm. Ltd
  • Reliance Telecom Ltd
  • BPL Cellular Ltd
  • Srinivas Cellcom Ltd
Source: India Telecom
Hope this helps..
Mar 30, 2010 | Sony Ericsson W910i Cellular Phone
Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
The cam wont take pictures and it automatically off,and it cannot play or see the pictures is it a software or hardware..
Approach Olympus service centres in india..
India
  • Camera Care Centre (Service center) (Mumbai)
    225, Commissiriat Bldg. Next to Old Hendloom House, Dr. D.N. Road, Fort, Mumbai 400001 India
    Tel : (91) 22-2261-1274, (91) 22-2261-4015
    Fax :(91) 22-2261-0219
    E-mail :cameracarecentre@gmail.com
    icon_w.gif:Worldwide repair warranty appointed members.
  • JSK Marketing Pvt. Ltd. (Ahmedabad)
    (Olympus Authorized Distributor / Service Centre)
    A/11/1-4 Ground Floor, Premium House, Near Grandhigram Rly Stn, Ellisbridge, Ahmedabad 380006 India
    Tel :(91) 79-2657-6296, (91) 79-2658-0296
    E-mail :service@jskindia.com
  • JSK Marketing Pvt. Ltd. (Bangalore)
    No. 21, 3rd Floor, Lakshmi Bldg,, Mission Road, Bangalore 560027 India
    Tel :(91) 80-4126-2558 ,(91) 80-4126 2559
  • JSK Marketing Pvt. Ltd. (Chennai)
    No. 1, Play Ground View Street, Nandanam, Chennai 600035 India
    Tel :(91) 44-6515-3437, (91) 44-6515-3438
  • JSK Marketing Pvt. Ltd. (Cochin)
    No. 37/1572, Ground Floor, S.C. Bose Road, Jawahar Nagar, Kadavanthara, Cochin 682020 India
    Tel :(91) 484-306-2877
  • JSK Marketing Pvt. Ltd. (Hyderabad)
    No. A38, Ground Floor, Opp. Park Lane No.2, Indian Airlines Colony, Begumpet, Hyderabad 500016 India
    Tel :(91) 40-6459-0668
  • JSK Marketing Pvt. Ltd. (Mumbai)
    27B, TV Industrial Estate, Basement,, Pandurang Budhkar Marg, Worli, Mumbai 110008 India
    Tel :(91) 22-2493-3943
  • JSK Marketing Pvt. Ltd. (Pune)
    687/8 Parrijat CHS, Plot No.1, Bibwewadi, Pune 411037 India
    Tel :(91) 20-2421- 1521, (91) 20-2421-1983
  • Shetala Cameras (Service center) (Bangalore)
    Unit no. 104, Ground Floor, Shree Complex, #73 St. Johns main Rd., Opp. Rbanms Ground, Bangalore 560042 India
    Tel :(91) 80-4123 8528, (91) 80-4123 8529
    Fax :(91) 80-4123 8527
  • Vision Solutions (New Delhi)
    314 Competent House, F Block, Middle Circle, Connaught Place, New Delhi 110001 India
    Tel :(91) 11-3264-9096
    E-mail :care@vdpl.in
Deleep
Dec 19, 2009 | Olympus FE-170 Digital Camera
User manual of Factron Schlumberger ATE 635
Check out http://www.schlumberger-ate.com/ they would be very interested if you ever got a manual.
Oct 24, 2007 | Computers & Internet
Service cente
This is the wrong venue for your request. You should apply to HP to become a qualified HP service center. Anyone attemping to repair HP equipment outside HP approval will invalidate warranttes.
Oct 06, 2007 | Computers & Internet
Problem in the camera
The Kyocera web site tech support, will have that information Manually pulling and pushing a stuck zoom lens will run it, It is a very delicate mechanism, and there will be no service option if it is broken.
Jul 03, 2007 | Kyocera Finecam S4 Digital Camera
Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump Logo
1,910 people viewed this question
Top Danfoss Garden Experts
Wayne Fellows
Wayne Fellows
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Danfoss Garden Expert? Answer questions, earn points and help others
