Question about ASUS K8S-MX Motherboard
My cpu does not take ShutDown Autometicaly.
Dear Sir,
When I Press ShutDown Command from START mode on my screen, after some time my pc tel me "It is now safe switchoff your computer" before sometime CPU switchoff autometicaly itself.
Please send me a solution for it on my mail address.
Your"s Faithfully
Hiren.
    Problem Solver:
  • 16 Answers
FOR THIS YOU NEED TO EDIT REGISTRY, AND BE AWARE OF THE FACT THAT EDIT REGISTRY CAN DMG YOUR OS!!!!
to edit registry you need to execute a program from the command option in your start menu ( dont know the exact name to execute, got no english version of windows).. but you need to execute regedit.exe
now you enter regedit, it's a kind of explorer type environment... go to:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
then search for the value
PowerdownAfterShutdown
behind that there is :
REG_SZ (String Value)
leave that alone.
then:
a 0 (zero)
that needs to be changed to 1,
you can change it by right click on "powerdownaftershutdown" and choose the top option (i asume edit (again no english version.or something)
now change it to 1, press ok, and exit registry editor, save it and problem should be fixed.
Posted on Jan 29, 2009
How do I restart or reboot my whole system and start fresh.I have a Dell latitude D430
Dell not given facility to reboot. But command through you can reboot . To access the command prompt window from Vista or Windows 7:
  1. Go to the Start menu
  2. Type cmd in the Search field
  3. Press Enter
On a Windows XP computer:
  1. Click the Start menu
  2. Choose Run
  3. Type cmd
  4. Press Enter
From an open command prompt window, you can type shutdown, and then the option you wish to execute.
To shut down your computer type: shutdown /s
To restart your computer type: shutdown /r
To log off your computer type: shutdown /l
0r
press down window key with and two time press "U" key.
Sep 19, 2013 | Computers & Internet
XP Home Boot Problem
Restore Computer:
To start System Restore using the Command prompt, follow these steps:
  • Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  • Use the arrow keys to select the Safe mode with a Command prompt option.
  • If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  • Log on as an administrator or with an account that has administrator credentials.
  • At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  • Follow the instructions that appear on the screen to restore your computer to a functional state.
  • After restoring. restart your computer and use system utility tool like Reginout to fix coorupt windows files.
Dec 27, 2011 | Computers & Internet
Won't start up after shutdown. suggests disc check but freezes.eventually comes on after skipping dosc check,but running slowly
If you do not shutdown your system properly means,that time only it will act like that that means file checking.
Steps 1.Kimdly diasble the all startup function (opent the run command and type MSCONFIG and automatiocally open one window and choose the STARTUP and diasable the all function)
2.kindly delete the all temporary file(open the run command and type %temp% and select the all file and then press SHIFT+DELETE,Sir.
3.And also delete the all the prefetch file
4.and also increase your catch memory,Sir.
5.And also increase your virtual memory,Sir.
Right click over the mycomputer and choose the properties and then choose the advance tab and then click the setting below the performance and then again click the advance and then choose the virtual
memory,Sir?
Nov 17, 2010 | Acer Aspire One PC Notebook
My a6700y has developed a startup problem. it takes about 15 minutes from start to desktop. blank screen and no cursor until then. I have also had issues with freezing and applications not responding and...
Restart your computer. Press F8 several times while it's booting up. This should get you a text screen that allows several Safe Mode boot up options. In safe mode, you have access to only basic files and drivers (mouse, monitor, keyboard, mass storage, base video, default system services, and no network connections). You can choose the Safe Mode with Networking option, which loads all of the above files and drivers and the essential services and drivers to start networking, or you can choose the Safe Mode with Command Prompt option, which is exactly the same as safe mode except that a command prompt is started instead of the graphical user interface. You can also choose Last Known Good Configuration, which starts your computer using the registry information that was saved at the last shutdown.
Safe mode helps you diagnose problems. If a symptom does not reappear when you start in safe mode, you can eliminate the default settings and minimum device drivers as possible causes. If a newly added device or a changed driver is causing problems, you can use safe mode to remove the device or reverse the change.
Sep 17, 2010 | HP Pavilion a6700y PC Desktop
Mynotebook compaq presaio c700 after formatting it gives me BOOTMGR missing msg,& shutdown autometicaly,& also very hot in lftside of my keypad,i can't able to start my work,for it,plz help,i also...
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully.
8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Sep 02, 2010 | Compaq Presario 700 470024-192 Notebook
Dear Sir sir i have hp desktiop pc and i have
You need to remove the Heatsink from the CPU and re apply heatsink compound to both the CPU and the heatsink then replace the heatsink onto the CPU. the reason for the overheating and shutdown is that the connection between the heatsink and the CPU has become "Aged" and no longer transfers the heat like it should
Jul 20, 2010 | HP Compaq d530 SFF PC Desktop
Internal microphone not working
I have Dell Inspiron 1520 and I have issue to built in microphone is not working. I tried to execute the Sigma Tel driver from Dell Driver and Support website but prompted 'Exit Error; Error : Device Object not present, Restart system and run setup. Then, asked Dell support to help and they are not really helpful, after System Restore and drivers upload and finally asked to reformat the laptop........
Anyway, this is what works for me.
1) Download the Sigma Tel driver from Dell Support Drivers page and save it in Desktop
2) Shutdown your computer
3) Start your computer and press F8 at the Dell Logo page
4) Select Safe Mode (not others)
5) Proceed to work on Safe Mode
6) Right-click the Sound icon and activate the Sound icon
7) Select Recording device.
8) If still not working, then execute the Sigma Tel driver that saved in desktop
then, shutdown the computer and start as normal, you may see the system able to detect the built in Microphone then.
Hope it will work the same for you too..!!
Apr 20, 2010 | Dell Latitude E6400 Notebook
Disk error in starting computer
Please Check You Disk By CHKDSK COmmand in dos
For it Press F8 Key continuously When Computer Started and Select Option Run In DOS MODE!!
VIkas Agrawal
MCA
Feb 09, 2010 | Computers & Internet
I am having problem in starting up my system.once system has shutdown ,it fails to start immediately after pressing the start button.even after 2-3 hrs it does not start on pressing the start button.but...
Sir,
Let me tell you that do not use UPS current on to the computer as the current in UPS is (AC) it would blow whole of the power supply or might effect to your Computer processor. As now you are suggested to get new power supply. hope fully this would work
Aug 30, 2009 | Computers & Internet
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
ASUS K8S-MX Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
