Question about Lenovo 3000V200 Laptop
Not getting the newly bought Lenovo monitor repaired
Bought a new Lenovo for about Rs.39000-two years back with much expectations.Monitor failed some 5 months ago some seven months after the expiry of 'Warrranty Period' of the whole set.Contacted the vendor and it is known that he tried but of no use.Reported failure of "LOT" and no scope of replacement of this part due to non availability.The cartridge of the printer also got exausted one year ago and that also could not be replaced yet.
Please inform me how can you help me before I tempt to throw away the set to some road-side scrap heap.
With sincere hope,
Prithviraj.G,
Paliakkara ast Palace,
Tiruvalla,
Kerala.(PIN).689101.
Kyun purchase kiya pehle
Posted on Jan 29, 2009
Black screen death
non working ram leads to no boot at all or crashes. if ur laptop able to boot but unable to detect the built in monitor while at the same time detects external monitor just fine then the problem probably lies on the built in monitor itself or probably some lose cable between the mainboard and the monitor. i can assure u the GPU is working fine. if u can locate the RAM, it doesn't hurt to check them out tho. try reverting to stock ram by removing the newly installed ones and see.
Aug 10, 2013 | Lenovo ThinkPad Computers & Internet
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
The monitor will display fpr 4 to 5 seconds and turn black! bought a new cable and still does the same thing. Bought monitor in may of 2009. should last longer then 1 1/5 years!!!!
There two boards that give trouble, the power supply board, and the inverter board that energizes the back lights behind the screen, failures are usually caused by bad capacitors and in some cases bulge at the top. To repair will need a service center and I recommend an estimate.
Feb 02, 2011 | Hannspree HW191D LCD Monitor
Can you please tell me the secret getting the cover? My monitor shuts off after acouple of minutes.If I wait 30 minutes or so it will turn back on. But just for acouple more minutes and it off again. I...
That sound like you have a component failing inside. Basically what you are seeing is the part heating up and then stopping. It cools off a bit restarts and you get a few minutes and it heats up enough and off it goes. If you have any warrenty talk to the store you bought it from and see what the process is to get it fixed. If you don;t have warrenty this can be iffy if it is worth fixing or just replacing. The repair can easily cost more than a new one. You might want to check around as well as talking to acer and the store about repairs. Don;t just get it fixed just an estimate. Do a bit of shopping and see what a new one is worth. If the new one is cheaper just get it. The repairs can be long or short term fix. It might get t working for a while or for a long time but you don;t know so unless the repair cost is cheap don;t bother and expect to see a problem sooner or later.
Jan 21, 2011 | Acer AL1916W 19" LCD Monitor
My acer monitor began to flicker for several hours and then it just went black. I bought it on February 27, 2008 from Consul Tech Computers in Kelowna, BC. and he is no longer in business. I would like...
Flickering monitor display (assuming graphics card and vGA cables are ok), are indicative of either a failing powerboard capacitor, a "dry joint" or other internal failures. I would also suspect the inverter as a prime cause here. Repairing... probably beyond the cost of a new monitor. As to any warranty with the original supplier, i'm in the UK so cannot advise what to do there. TBH: 3 years from a monitor is about the life span depending on how much use it gets
Jan 08, 2011 | Acer X193W LCD Monitor
I bought my emprex monitor 3 yrs back. For all these years it had worked its best. But now, when the computer is powered on, the screen flickers by producing small poping sound and goes black...please...
Yes it can be repaired usually just easier to by a new one. it sounds to me like it is a power supply for the monitor. The only hard thing would be getting the power supply for the monitor. Your can try contacting the manufacturer for it :) hop this helps
Dec 27, 2010 | Emprex LM2201 22" LCD Monitor
My Acer AL1917WAbd 19" LCD powers off ~2 second after power on.
The monitor this old I will not be surprise if you will find a lot of bad caps inside, see what goes wrong with LCD monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
If you have it repaired, you will more likely to be charged $80~90, I would put that money toward a new monitor, just do not expect them to last more than 3 years on the new monitors.
Apr 07, 2010 | Acer AL1917WABD 19 inch Monitor
The power switch broke (won't click to turn on). How do you take the back cover off the monitor?
Is it New Monitor?? or Bought within lat 2 years Call Dell,At the back you can see 20 Digit Serial no give this no and say my monitor power switch is broken You will get a Replacement Monitor ** Dont Remove Any parts of your Monitor **
Jan 07, 2010 | Dell E228WFP LCD Monitor
Lenovo 3000V200 Laptop Logo
37 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
